restoring 20' cig.... NEED ur Thoughts!!! need info!!! >
Old 10-06-2010 | 10:48 AM
  #221
Originally Posted by tomuchstuff
Thinking about rigging...
I have some options
#1 Arneson makes a helm kit that includes: helm, reservoir, two lines, power steering pump, cooler. The system is rated for use with the 1720, 1721/asd6 at its max torque rating 700fpt, the single ram kit cost only $630 new + freight...
#2 I do have the same used arneson steering kit all ready I was thinking about using but its used..
#3 I have a new Latham LM14 system.. The LM14 helm is made for two #6 drives and will give you about 4 turns lock to lock with the two drives using four #6 cylinders. With only one ram I'd only have about 1 turn lock to lock, I think that is too touchy. I was thinking about how the capilano helms I used in my bertram have a nob connected to a proportion valve that is in the helm that controls the amount of turns the wheel makes lock to lock... I was thinking if I run the Latham LM14 set up and add a proportion valve on the fluid line connected between the helm and the input side of the ram I should be able to control the psi and the turns lock to lock. That will give me the very cool choice of setting the lock to lock as I want... Has any one done done this with a full power helm???
In case any one was wondering the Latham idea will not fly with a proportion valve. maybe with a dump valve, but I don't think its worth it...
tomuchstuff is offline
Old 11-10-2010 | 03:56 PM
  #222
Whats the latest?
TxHawk is offline
Old 11-15-2010 | 03:41 PM
  #223
Originally Posted by TxHawk
Whats the latest?
http://picasaweb.google.com/lh/photo...eat=directlink
finishing the WRX still... almost done, the bertram in next in line for two or three weeks, then the 20' cig will be ready for some more love...
Old 11-23-2010 | 11:31 AM
  #224
looks like I'll be finishing the cigarette b4 the b35. I pulled her to the shop so I can finish the body work, paint her and build her.. I'm going to have to chose between the arneson 1720 or asd6 drive and pull the trigger on an engine...
we will see
Old 11-25-2010 | 01:10 PM
  #225
Default twin arnesons in drag boat style
well I have been giving this a lot of thought and have the parts to make it happen..
run two new 1720 arneson drives, counter rotating like the fastest drag boats in the world..
here is the idea..
I'd put two in line drives as the factory instructs on my boat, mount them so I have 12" between propellers. I'd use 4 super charger style or custom industrial factory pulleys and a toothed blower belt I can make a RR drop box that will take well over 1000hp with no drag from an oil sump. I'd need have a coupler pulley & maybe some pulleys to fit the 1720 input spline, build a tensioner pulley carriage to hold a pulley above the out put shaft pulley on the velvet drive..
I have talked to velvet drive and they say it will not damage the drive to have pressure on one side of the transmission out put shaft... but seeing as a tensioner pulley carriage will need to be built any way to revers the rotation I'd think a raced bearing shaft supported pulley can be built in for a proper drive coupling.
it be much simpler to change ratios, no oil or lube, less drag the gear or chain drives, good for the same hp...
but I can just bolt one 1720 in line or one asd6 to the back and put a sbc in and be done with it.. lol
it'd look super cool to have a little cig with twin arneson's then she'd have the big gun look all the way.....
Old 11-29-2010 | 06:50 PM
  #226
Default finishing the body work
The bolt on wind screen will be ready to make the fiber glass mold in the next day or so, it will be nice to get rid of the 40lbs of faring compound..
Old 11-29-2010 | 06:54 PM
  #227
still has to be able to go back to stock so also working the dash.
Old 12-22-2010 | 08:50 PM
  #228
Default about to mold make a mold of the wind screen
Old 01-03-2011 | 02:25 AM
  #229
Default snowing ever coat in fla
still plugging away at it here.....
Old 01-06-2011 | 10:22 PM
  #230
Default what a pain in the as$
So close
Still couple days b4 I can cover the screen with mold release and pull a lighter kevlar & useable window screen.... funny all this work just going in to the dumpster once the mold is pulled...
I just have to work out the side angles a little and extend them a bit photo #3 shows the extensions in place but I still need to glass and faired them to be finished... The extensions will now stop at the end of the cockpit right at the rear seat back...
The rear deck and transom that was cut out for the o/b is fixed but with this cold wether in the 60's the awlfair kicks slow 36 hours ... I'll toss some photos up...
I also welded up an aluminum drip rail frame that will be both bolted and glassed into the rear seat to make a large engine hatch... I plan to fully kevlar the kevlar-cabin floor to the stringers and hull sides, this along with the seats new drip rail/frame "that is copied after a swing out door kit used on drag cars".. The boat will be 100's of times stronger then the factory bulk head system as the 20' only has two single layer 20 oz roving tab's by the tow panel abut 6x6" and the fuel tank box was in closed with a single layer of the roving on both sides..... building a new kevlar 1/4 tab on both sides of the stringers and to the hull will be over kill but very strong
I am also using west systems product for sealing the deck to the hull...
