LED Bilge Lighting >
LED Bilge Lighting
LED Bilge Lighting
Old 01-28-2013 | 08:27 PM
Couple questions, are you guys tapping into your existing bilge light to turn on and off and what are you using to mount them? Double sided tape wouldn't cut would it?
jbraun2828 is offline
Old 01-28-2013 | 08:40 PM
Its such a general question. Theres a ton of LED products and companies its like asking which bread should I eat. Just pick the one you like and go with it..
But since the question was asked I cant miss an opportunity to post a pic
$22 for 16' waterproof roll ...can`t go wrong
ICDEDPPL is offline
Old 01-28-2013 | 08:42 PM
Yes and yes... 3M 150' roll at home depot $15
ICDEDPPL is offline
Old 01-28-2013 | 09:03 PM
I'm going to set them up on their own switches.. just not sure that I can justify the $ for the stingerz. May go with the ledglow..looks like a nice set up for the $
Drock78 is offline
Old 01-29-2013 | 12:17 AM
Randy Nielsen's Avatar
Default Ledglow
I used ledglow on mine. They are remote controlled & can be hooked into the stereo also. These pics are blurry cause the camera wouldnt focus right but show how much they light up. I have six more small tubes I can mount but havent done it yet. Randy
Attached Thumbnails LED Bilge Lighting-001.jpg   LED Bilge Lighting-004.jpg   LED Bilge Lighting-005.jpg
Randy Nielsen is offline
Old 01-29-2013 | 01:56 AM
You have the color changing?
Drock78 is offline
Old 01-29-2013 | 02:30 AM
You can change color, dim, run chase patterns and hook to stereo all remote controlled with a keyfob. The kit is also expandable. www.LEDGLOW.com entire kit about 175.00 Randy
Old 01-29-2013 | 06:14 AM
I had a spare accessory switch in my dash so when I had the interior out I just ran wiring direct up to the switch in the dash. I used plastic squares with a little "tab" in them and epoxied them up under the gunnels then wire tied the light strips to the tabs...shouldn't go anywhere
I wish I had some pixs of them lit...all these lit engine bays look awesome! Can't wait to get my boat back and turn on the lights
jasonmd2 is offline
Old 01-29-2013 | 06:18 AM
How many strips do you have in the bilge
Drock78 is offline
Old 01-29-2013 | 06:46 AM
Do you have a link to where you bought your lights?
Drock78 is offline
