One of the five becomes a Six >
Old 04-06-2016 | 08:38 AM
  #321
Originally Posted by Zero Patience
We both run 15 rake, the fuel was and is 93 unleaded, ethanol. Pump gas. We will put the video up of the Dyno . On our run last Friday the whipples were wet with condensation, and cold to the touch.
Did you guys test any 18 degree rake?
kvogt is offline
Old 04-06-2016 | 11:03 AM
  #322
Originally Posted by mmb
You put new engines in?? Or are those N/A motors running that strong?
I believe he had them redone and added prochargers .
MILD THUNDER is offline
Old 04-06-2016 | 07:20 PM
  #323
Zero Patience's Avatar
Originally Posted by frickstyle
Zero,
Are there any advantages when running the whipples in relation to octane ratings? I would assume that detonation has more to do with the cylinder head design and hotspots inside the engine/combustion chamber/ cylinder (also a relation to intake temps).?
I.E. - "I can safely make 50 more hp at the same octane rating, compression ratio, # of static boost with the Whipples". Or maybe is it that they are just more efficient therefore yielding a better average horsepower under the curve, and possibly a higher peak. Or can you actually run additional/more boost everything else being equal. Does my question make sense?
(I may have answered my own dumb question....)
Wow, we leave that stuff to Chief Engines, Tommy has always built us engines that run like a Rolex. For hundreds of hours, 436 on my last pair of blower motors. He makes the decisions, we ask the questions.
Zero Patience is offline
Old 04-06-2016 | 07:24 PM
  #324
That right there is what its all about!
Old 04-06-2016 | 07:40 PM
  #325
New engines by Dave at WESCO...1200hp's with M4 ProChargers...pump gas with BOOSTANE. Turning 4 blade 34's on sixes. Close to the same set up as when Craig had it.
38Raptor is offline
Old 04-06-2016 | 09:21 PM
  #326
^^^^ How many hours on them things now? Thought you threw a rod first time out, what was the issue if you don`t mind me asking?
Btw, how do you like that BOOOSTANE stuff?
ICDEDPPL is offline
Old 04-06-2016 | 09:53 PM
  #327
Catastrophic part failure did occur - brand new valve broke, big time, after only 3 hours runtime. Exploded a new $$$ motor. Hoping the valve brand steps up and makes it right with Dave - the valve head literally just broke off....3800 rpm @ 70mph cruisin' when it broke.
BOOSTANE is incredible - I'll never run my boat without it again. Using one can per 100gal w/93 octane. Cheap insurance - it's not so much about getting a boost in octane level for me as it is treating the fuel in case you get crap gas somewhere...I know how that movie ends from years past also
38Raptor is offline
Old 04-07-2016 | 06:47 AM
  #328
offshoredrillin's Avatar
That boat was always a solid runner, even with the n/a 850s it was an 87 mph ride. I agree on boostane, i have it for the same reason, just insurance on the water when filling up. I do 2 cans per side, when buying gas on the water. One if i fill up on land.
offshoredrillin is offline
Old 04-07-2016 | 07:13 AM
  #329
Whats the difference in the premium & professional BOOSTane?
jmoore1225 is offline
Old 04-07-2016 | 07:45 AM
  #330
Look at Iced's avatar think she's been running booty boostane!!!
shepnic74 is offline
