Replacing Dash Panels - Help >
Old 01-11-2005 | 03:30 PM
CIG3's Avatar
Default Re: Replacing Dash Panels - Help
BUy a Brother "P" touch to make your labels not to expensive and makes life easier to read.
CIG3 is offline
Old 01-11-2005 | 04:16 PM
The Menace's Avatar
I have a buddy who works in the machine shop at a Ford plant. They do remarkabe things with their spare time (which is all of their time). They removed the 6 dash panels from the cat and are in the process of duplicating with marked improvements. The Garmin 182C will be recessed into the dash and will rotate up to 90 degrees for running.
This includes professionally engraving all the switches and poistions. Most machine shops can easily replicate the panels.
Priceless.
The Menace is offline
Old 01-11-2005 | 05:04 PM
GLH's Avatar
GLH
Here's how much they had on our Tiger when Phil had the panel re-painted by Grafikworx. Mine is a 2000 so i bet yours should have the same slack in the wiring
Hope this helps.
Attached Thumbnails Replacing Dash Panels - Help-.jpg   Replacing Dash Panels - Help-aa.jpg
GLH is offline
Old 01-11-2005 | 05:24 PM
P Offshore's Avatar
GRS,
Check your PM.
It is not hard to do, take your time and label everything.
Good Luck
P Offshore is offline
Boomer35
Cigarette
7
04-26-2008 11:57 AM
95caliber
Baja
25
05-13-2006 06:43 AM
Vyper340
Powerquest
11
03-24-2006 05:46 PM
OldSchool
11-17-2003 06:03 PM
Horseplay38Cig
05-12-2002 12:49 PM
