Bringing Back A Legend (Rascal) >
Old 05-01-2012 | 04:25 AM
  #51
Scarab3DMC's Avatar
Originally Posted by legend
glopra what a family of off shore racing. That was when racing was racing. You think you can read waves then try lake erie. It's the only body of water that can create 4 to 6's with 2 foot speed bumps in between. The wind will switch 180 degrees in 1 minute or build 12 foot waves in ten minutes. " off shore supercross "
amen to that!
Scarab3DMC is offline
Old 05-07-2012 | 12:59 PM
  #52
The cockpit transformation is coming along good. The cockpit area was filled with fuel tanks and extra aluminum for the bracing of the canopy. A couple of hundred pounds of aluminum where taken out for that. The cockpit floor area had extra's that had to be cut out to get back to the old floor platform. this week I am welding in the new dash panel the full length of the top forward edge of the cockpit and edge of the deck. I found a very good welder that will dime weld it so not to have to grind down the welds to keep that machine look. I have the floor panels cut out and the sides of the cockpit will be diamond plate.
I also added a picture of the inside bow structure. Remember this was built in 1973 when most aluminum boats had regular plate stringers and ribs. Most of the Rascal's structure is bent aircraft aluminum for strength and less weight.
Attached Thumbnails Bringing Back A Legend (Rascal)-rascal-031.jpg   Bringing Back A Legend (Rascal)-rascal-030.jpg
legend is offline
Old 05-17-2012 | 07:28 AM
  #53
CIG3's Avatar
What did she weigh?
CIG3 is offline
Old 05-17-2012 | 09:33 PM
  #54
Originally Posted by CIG3
What did she weigh?
If my math is correct 5,600
legend is offline
Old 05-18-2012 | 01:45 PM
  #55
Default Rascal
Here are a couple with the wind screen put back on. Pre fit and drilled before stripping and painting.
Attached Thumbnails Bringing Back A Legend (Rascal)-rascal-restoration-006.jpg   Bringing Back A Legend (Rascal)-rascal-restoration-007.jpg   Bringing Back A Legend (Rascal)-rascal-restoration-008.jpg
legend is offline
Old 05-18-2012 | 03:18 PM
  #56
TENSION's Avatar
Love the windscreen!
TENSION is offline
Old 05-19-2012 | 05:11 PM
  #57
It's been a while since she wore that hat. I didnt think the engine hatch intakes would look good with the wind screen but they look perfect together. It's going to be a year or two before power is installed but this nice weather is making the wait hard. Starting to shop.
legend is offline
Old 05-19-2012 | 05:19 PM
  #58
lucky strike's Avatar
Awesome job!
lucky strike is offline
Old 05-22-2012 | 12:13 AM
  #59
Had the privilege to talk to Phil Caricoff this week. What a boat designer and building Legend! Sent him some pictures of the Rascal. He has not seen the boat since his company built it in 1973. What a thrill it must be to see one of your works of art thirty nine years later. His boat designs are spread out from Italy to the Hawian Islands. What an accomplishment.
legend is offline
Old 05-24-2012 | 11:05 AM
  #60
The decision has been made. Staggered 540's with 13/4 drive shafts out the back of transom on the surface with single rudder. Simple and sweet.
Attached Thumbnails Bringing Back A Legend (Rascal)-rascal-restoration-009.jpg   Bringing Back A Legend (Rascal)-rascal-restoration-010.jpg
legend is offline
