Cortes Mirage Info
Old 12-08-2015 | 08:13 PM
  #61
Lightspeed, I would be interested in more info. Not too many Mirages out there. Thanks.
Thriller62 is offline
Old 12-08-2015 | 11:46 PM
  #62
h2oboater's Avatar
Originally Posted by lightspeed
yes they made a 25 looks just like the 30,, but very few
Right you are I forgot about this thread, if you red post # 4 they mentioned them.
http://www.offshoreonly.com/forums/c...32-mirage.html
h2oboater is offline
Old 12-09-2015 | 07:04 AM
  #63
I wonder how close in design my 29 Cary is to the Mirage. Mine measures 29'9". Is the Mirage exactly 29'?
Cary 29 is offline
Old 12-09-2015 | 03:22 PM
  #64
gunwale length 29'8' centerline length 29' even.
Old 12-11-2015 | 07:55 AM
  #65
Thanks for the info Thriller. Bottom probably same 24 degrees all the way to the transom.
Cary 29 is offline
Old 12-11-2015 | 07:47 PM
  #66
Compare strake width at the transom between the Mirage and Cary.
Jeff
hallj is offline
Old 12-11-2015 | 09:28 PM
  #67
Yes. It's 24 degrees all the way down
[ATTACH=CONFIG]548696[/ATTACH]
Old 12-12-2015 | 03:57 PM
  #68
Jeff
My strake width is aprox. 3 1/2"
Cary 29 is offline
Old 12-13-2015 | 03:04 PM
  #69
4" on the mirage
Old 12-13-2015 | 08:04 PM
  #70
So this tells us that the Mirage is most likely popped from a 28 Cig and the Cary is popped from a Magnum.
Cortez worked for Cigarette with Sonny and Bob at the time the 28 was built. They used a Magnum hull, added the second rub rail line and widened the strakes by a 1/2".
Makes sense,
Jeff
hallj is offline
