Under Hatch Mirrors
Old 01-30-2010 | 12:10 PM
Originally Posted by justincasey57
how would you attach this?? epoxy?
3M 5200 worked for me and did not effect the mirrored underside coating. Started with a special plastic mirror adhesive and it did not hold well under heat and stress.
CignificantOther is offline
Old 01-30-2010 | 01:25 PM
502ss whats the name of the stuff you bought from the website posted?
There are different types. I went with acryclic mirror. Plenty of colors to choose from too!
http://www.curbellplastics.com/sign-pop/mirror.html
I used 1/4-20 Stainless button head allen bolts to attach my pieces.
502ss is offline
Old 01-30-2010 | 09:35 PM
The 3m 5200 or otherwise the urethane inshields are installed with would work fine. Most now a days require a primer you apply where the urethane is applied. You just use a swab type deal that comes witht he primer. Be sure and use the primer for good adheasion. Personally I would mark the area well where the mirror is to be placed and outline it lightly. About every 8 to 12" or so squirt out about a ping pong ball size of urethane. Press lightly to some what firm evenly throughout. Tap the edges and let sit over night. If your hatch cover is off you need not tape.
getrdunn is offline
Old 01-31-2010 | 09:13 AM
502ss I see what your talking about but I dont see any prices. I sent in a price request but havent heard from them. any idea of the cost of a 4x8 sheet is? thanks
justincasey57 is offline
Old 01-31-2010 | 10:39 AM
Not sure about a 4x8 sheet but I purchased 2 pieces 24"x40"x1/4" thick. It ran me about $130.
It does suck that they dont have prices on their website but I purchase supplies from them for my business so I usually just drop them an email or phone call. I dont believe they are open on weekends so you should here something Monday.
...Jim
502ss is offline
Old 01-31-2010 | 04:22 PM
It's also available in 1/8".
getrdunn is offline
Old 02-03-2010 | 08:29 PM
GO4BROKE's Avatar
I attached mine with 3m emblem adhesive 2 sided tape. It has held for 12 years of rough water. Prepping the surface with 3m adhesion promoter will make it even stronger.
[img][/img]
GO4BROKE is offline
Old 02-24-2010 | 11:02 PM
Strip Poker 388's Avatar
Rob
Originally Posted by cabana1
I got mine from a place up here in Cincinnati called GE polymer. A 4x8 sheet was a little under a hundred bucks. Then i cut it close to size with a table saw and fine tooth blade. Router or jig saw works good too.
I'm paying 140 for a sheet 40 to cut to my template and I get the droppings,so far I'm out 540 and 3 broke mirrorsIve got to find a better way to attach it,I have screw heads that hold the hatch pad on, maybe a spacer behind the glass so it want crack tighten down on the cover, the 3M tape is working on the other glass.just have to cover the screw heads and the sides it needs a backing to protect the silver.
Attached Thumbnails Under Hatch Mirrors-boat-car-show-jan-2010-026-large-.jpg   Under Hatch Mirrors-boat-car-show-jan-2010-028-large-.jpg   Under Hatch Mirrors-boat-car-show-jan-2010-025-large-.jpg
Strip Poker 388 is offline
Old 02-24-2010 | 11:36 PM
Default attaching mirror plex under hatch
I used stainless steel screws and finishing stainless steel washers on my 36 outlaw and they worked great.That way if i needed to remove sun pad it would be easy to remove mirror plex.Good luck
Hank36 is offline
Old 02-25-2010 | 06:52 AM
looks great strip
brians fever is offline
