Engine Build Finally Under Way!! >
Old 09-30-2010 | 10:54 PM
Default Fixx
im running a 355,srp flat tops, aluminum heads tho and a bunch of other goodies..750 cfm proform carb.. runs like a scalded dog..have a friend running a similar set up like yours and also ran a 750 carb.
FIXX is offline
Old 09-30-2010 | 11:56 PM
what kind of rpms are you guys turning?
87MagnumII is offline
Old 10-01-2010 | 01:04 AM
motor runs strong about 400hp give or take a few my carb is a holley 650 4barrell electric choke dual feed i think its a 4150 was built by all island carb on long island ny .i sent them my 750 edlebrock to rebuild because i was fouling plugs ,running rich etc and they told me that thier was nothing wrong with my carb what motor was it on and what was my hp and said my problem was it was over carburated and built me a 650 for my set they put it on a dyno and run it to your rpms and timming and set everthing so when u get it just put it on and go
innerrage is offline
Old 10-01-2010 | 01:12 AM
my motor rpms are from 5200 to5500 run a 14,25x23ss left on a 290a volvo drive
Old 10-01-2010 | 05:57 PM
Default Fixx
[QUOTE=87MagnumII;3220755]what kind of rpms are you guys turning?
24 ultra labed 6200 max !! 26 ultra labed most of the time 5800 rpm's.. standard volvo penta 280
FIXX is offline
Old 10-02-2010 | 12:41 AM
valves are in, rockers are on hand tight, putting the heads on the block monday to check pushrod clearence, will post more pics soon
Old 10-08-2010 | 11:07 PM
will the valve cover tubes that the bolts go through clear the rockers, just did a motor and they did not cleatr the rockers.
fkboatman is offline
Old 10-11-2010 | 09:08 PM
i think im gonna have to get bigger valve covers. any suggestions??
Old 10-15-2010 | 07:01 PM
ok just pulled the old engine today. it is a 2 piece rear seal 350. besides the flywheel and coupler will everything else change over to my new 1 piece seal block, such as starter, p/s pump, harmonic balancer, bell housing, etc etc?
Old 10-15-2010 | 09:38 PM
Yessir! As long as you run the same diameter flywheel the starter will be good. Some of the older 350's had a 158 tooth ring gear which takes a different offset then the 168 tooth.
HaxbySpeed is offline
