Hynautic steering help
Old 08-03-2012 | 06:14 AM
rams should be fine...there are some specs you can modify a car pump to make work..but the marine pump is WAY different..as I found out...AGR makes the custom marine pumps...they have more PSI at lower speeds and less pressure at higher RPM as well as a bearing on the shaft instead of a bushing...
ezstriper is offline
Old 08-03-2012 | 05:05 PM
Russ G's Avatar
Fellas will these lines work from the helm to the power steering pump.
http://item.mobileweb.ebay.com/viewi...id=00318795251
Russ G is offline
Old 08-05-2012 | 08:43 PM
if you have to change hoses, do yourself a big favor and have them made locally with press on ends..you won't be sorry...
