How can you tell what scored your cylinders?
#61
yea, its pretty much a kill setting for this motor. When refire it it will be there. Pfaff had it set at 8deg. !? Then they shut it off and could not turn the disrtib enough so they moved all the spark plug wires over 1 pin .(which turned out to be 40) Refired it, ruined the cam and sent me to the lake to run it for 45 min at 3000- 4000 rpms . On 7 cyl 😝 lol.
#62
Only if they had to crank the schit out of it and it wouldn't fire...or the like.
IE: Not doing the flat tappet break in process correctly.
#64
Wreckin tha cam is one thing . Sending me to the lake w 7 cylinders and wreckin everything else terrible. And i dont have any money to throw at it once they take it apart and ask for more like they do . I have a 19 month old son now . And he can't go for boat rides because of it . If it were me i , i would stand behind the work . But i am honest and genuine
#65
mcpro,several people including myself told you not to go with a flat tappet camshaft but you knew better and used it anyway.now you understand why we said to go with a roller instead of a flat tappet.when this engine gets done again are you going to use another flat tappet camshaft?
#66
The sticks were off a 1/4 inch at 3500 and Pfaff told me to adjust them the same 😁
#67
Were you trying to do the cam break-in after the motor was installed in the boat? I would try to at least find a startup cart to run it on and break in the cam before even thinking about dropping it in the boat. Better yet, get it on a dyno. The dyno is money well spent, IMO. Not only do you have controlled conditions for your break-in, but you have some real world data to use to help get it dialed in to run in the boat. If you can find a shop who can dyno it fully dressed with wet exhaust, that is a bonus.
#68
If I was dead set on using a flat tappet I would just spend $1500 on a tool steel core. Then you never have to worry about the cam going bad. Everything else will be rotted away and still have a nice shiny cam... $1500 might sound over the top but it's a lot cheaper than rebuilding a motor and popping cams in and out.
#69
#70
gosh i really apriciate the help, Mike also stated i could get some high end lifters as well. But honestly the thing ran for 10 years before water got in the exhaust and quenched the seat backin it in the water. I'm gonna make just like it was . Probly a 10 under crank and bigger pistons , but it will be just like new ! With better pistons. Pfaff racing engines couldn't do it. Does not mean it's impossible , just means they're crooks
