Which harmonic balancer?
Old 09-06-2018 | 06:38 AM
Originally Posted by abones
Has any one had issues with stock GMPD Dampners? for 5K and under use..
No...ran for years and still do..
ezstriper is offline
Old 09-06-2018 | 07:28 AM
i run boat weekly - year round (FL) - I was leaning toward Fluid Dampers until I saw the above.... now I'm waffling. Which ones specifically for a reasonably priced damper for a basically stock 454 mag? Keep in mind these wont see 5000 rpms.
Swamplizard is offline
Old 09-16-2018 | 02:13 PM
ATI hands down.
Disturbing Behavior is offline
Old 09-16-2018 | 04:42 PM
BUP
Originally Posted by BUP
depending on the build and balance --- 1 ATI balancers and then Power bond balancers by Dayco or vise versa. I believe dayco bought powerbond
Totally agree with the ATI like above ^^^^^^^^^ in post # 23 states.
BUP is offline
Old 09-17-2018 | 01:05 AM
On an internally balanced engine should a damper fail do you need to pull the thing apart to balance again with a new unit?
Baja Rooster is offline
Old 09-17-2018 | 09:45 AM
bck's Avatar
bck
Charter Member#568
The 540 ci 600 hp Volvo engines used GM dampeners. That being said, I dont know if they had issues with them.
Straight bottoms and flat decks
bck is offline
Old 09-20-2018 | 11:27 PM
I’ve alread had my 509 balanced with the flywheel and balancer. Is it possible to switch out the balancer at this point?
Old 09-21-2018 | 07:59 AM
I was in the same boat. I was worried about the balance issue being an external balance setup. Took my new powerbond balancers in along with my original gm balancers to the machine shop. They were within a C hair from each other. Was kind of a waste of money, but at least it made me feel better when buzzing along at 6k.
MILD THUNDER is offline
Old 09-21-2018 | 11:33 AM
That’s good to know, MT. From what I’ve read on the internetz unless a machine shop modified the balancer instead of the crank to balance the assembly the units are pretty standardized.
Old 09-21-2018 | 09:48 PM
the factory gm balancer for your 5000 rpm application is fine.what happens to them is with years of use the rubber will break down,that can be a big problem.
mike tkach is offline
