a1000 pump
Old 10-17-2018 | 07:04 PM
Default a1000 pump
ok sooo here's my question does anyone feel thar 1 single a1000 pump could support 2 500 efi engines with separate by pass regulators?
freekazoid is offline
Old 10-17-2018 | 07:38 PM
Tinkerer's Avatar
I would have two separate smaller pumps for redundancy.
one pump fails you can still get home.
Tinkerer is offline
Old 10-17-2018 | 07:40 PM
what pumps is everyone using for NA efi engine's?
Old 10-17-2018 | 08:22 PM
Tinkerer's Avatar
I believe that is the pump I am using for my 598.
But I am north of 800 HP
Tinkerer is offline
Old 10-17-2018 | 08:26 PM
BBYSTWY's Avatar
I have an extra a1000 that I plan on posting in the swap shop soon if you're interested....if they are stock 500 efi's I think that pump is way overkill...whats wrong with the stock setup??
BBYSTWY is offline
Old 10-17-2018 | 09:12 PM
I am running an a1000 with a 713hp 540. I also ran it on my previous motor that was a 540 with 500efi injection. Does not really matter if the pump is too large if you are returning the extra fuel to the tank. Jeff wurl
jwurl is offline
Old 10-17-2018 | 09:33 PM
they have cams in them. every one says ditch the cool fuel. and to be honest it gave me nothing but problems after i did the cam swap. not to mention there a pain in rhe azz to service.
do i REALLY need a Marine rated pump?
i was looking at the holley in line for half the cost as well.
Old 10-18-2018 | 12:31 AM
BBYSTWY's Avatar
Mine is not a marine pump for what its worth..I didn't run the a1000 because I didn't want to upsize all of my AN fittings that I already installed for the fuel system...plus I have 2 tanks 1 engine so a return style regulator would have been a nightmare...I'll look up the unit I'm running and post it for you...very nice relatively inexpensive product and it has a built in regulator that can be ran as a bypass or deadhead
BBYSTWY is offline
Old 10-18-2018 | 12:33 AM
BBYSTWY's Avatar
https://www.holley.com/products/fuel...arts/30-175QFT
BBYSTWY is offline
Old 10-18-2018 | 06:35 AM
F-2 Speedy's Avatar
That pump will not support EFI ^^^^^^^
F-2 Speedy is offline
