Bbc 454 build.
Old 10-06-2020 | 07:56 PM
  #181
did he send you cam specs?
mike tkach is offline
Old 10-06-2020 | 08:58 PM
  #182
Rookie's Avatar
Originally Posted by JaniH
Tel me more my funny friend!
I have no interactions or comments on Cstraub, good nor bad. I have been on multiple forums that he has been removed from over the years. Whenever the name is mentioned there is always good entertainment to follow. I believe he is also banned from this forum. Do a search in the tech section.
I don't believe you will get a bad cam selection from him, you're building a 454 that isn't extreme.
Rookie is offline
Old 10-07-2020 | 09:19 PM
  #183
why in gods name you looking for a spec'd cam from that snake oil salesman when 731,741 was all you needed.
sutphen 30 is offline
Old 10-08-2020 | 01:32 PM
  #184
Isnt it nice to see something different? 509cid with peanut port heads and straub cam. And no i am not a troll. One guy here made 461cid with merlin oval port heads, crane 731 cam, 9.5 compression. it made 460hp @ 5500rp, 494lb @4200rpm, without aceccories, CMI e-top headers, that did not impress me. Torque numbers of that combo was way off from my goals, goin to run mine in the same dyno. I have said this before but my boat is 26ft long, 24 deg V-hull, easily 6000lbs with all the stuff and passengers, original setup is twin sbc from the factory, so i am trying to make low end torque without losing too much from top. in my boating area i cannot cruise @3500 like the most of you, not even 3000rpm, 2000-2500rpm would be perfect cruising speed for me. Seems that this is the type of engine everybody hates in this forum. Hoping to get over 500hp with flat torque curve.
JaniH is offline
Old 10-08-2020 | 02:17 PM
  #185
Final engine specs. feel free to estimate power/torque
-Gm 502,gen6 block, bored 030 over, bores notched.
-Eagle forged crank
-Eagle 6.385 h-beam rods, l19 bolts
-Mahle -13cc dome powerpack forged pistons
-Comp ratio 9.5:1
-Quench: 0.037"
-Gm 360 casting peanut heads,ported, stock size 2,06"/1,72" ferrea stainless steel valves, intake flow with intake manifold, bad 273cfm @ 0.600" lift, good 283cfm @ 0.600" lift, exhaust 202cfm without pipe.
- Weiand street warrior 2123, dual plane intake
-Rochester q-jet 800cfm
-Crane gold 1.7 rockers
-Gm roller lifters
-Comp 930 valve springs
-Cam specs=?, will post the specs later
-Melling select series HV oil pump
-8qt marine oil pan
-merc thunderbolt ignition
-Stainless marine exhaust manifolds, 6" taller risers, vertical part of the riser extended 4" to silent choice diverters.
-Bearing clearances: mains 0.0031"(number 5=0.0039"), rods 0.0029".
-Piston to wall clearance: 0.0065"
JaniH is offline
Old 10-08-2020 | 03:18 PM
  #186
not yet, ill post the specs when i get them.
JaniH is offline
Old 10-08-2020 | 05:33 PM
  #187
What will your cruise speed be at 2000-2500rpm?
underpsi68 is offline
Old 10-08-2020 | 07:51 PM
  #188
merlin heads suck,enough said,can't believe it even made that much power.
Old 10-08-2020 | 08:33 PM
  #189
when torque is measured on a dyno, the engine is typically at wide open throttle. So your 2500-3000 rpm part throttle cruise is completely different from 2500-3000 rpm wot pull on the dyno.
Unlimited jd is offline
Old 10-08-2020 | 08:36 PM
  #190
-Eagle forged crank
-Comp ratio 9.5:1
-Quench: 0.037"
-Gm roller lifters
-8qt marine oil pan
youd be better off selling the short block and buying a clean 330. And bore notching a 509 with those heads is a waste of time. This combo won’t make power past 4200 rpm
