Bbc 454 build.
Old 10-13-2020 | 08:25 PM
  #201
Rookie's Avatar
Rookie is offline
Old 10-13-2020 | 08:44 PM
  #202
$700 for one cam!?
MILD THUNDER is offline
Old 10-13-2020 | 08:49 PM
  #203
SB
Originally Posted by MILD THUNDER
$700 for one cam!?
A person the other year got a cast cam for that $$$&. Thus my questions on cam core type.
SB is offline
Old 10-14-2020 | 03:56 AM
  #204
Originally Posted by SB
Is the cam core 8620 ? Cast ? Or ?
Also missed one of my questions. Why did he andy/or you feel worth to go with 2 different intake lobes ?
SADI cam core. I am not an expert, but i think the reason for two different intake lobes can be found from head flow numbers i posted before.
JaniH is offline
Old 10-14-2020 | 04:08 AM
  #205
Final engine specs. feel free to estimate power/torque
-Gm 502,gen6 block, bored 030 over, bores notched.
-Eagle forged crank
-Eagle 6.385 h-beam rods, l19 bolts
-Mahle -13cc dome powerpack forged pistons
-Comp ratio 9.5:1
-Quench: 0.037"
-Gm 360 casting peanut heads,ported, stock size 2,06"/1,72" ferrea stainless steel valves, intake flow with intake manifold, bad 273cfm @ 0.600" lift, good 283cfm @ 0.600" lift, exhaust 202cfm without pipe.
- Weiand street warrior 2123, dual plane intake
-Rochester q-jet 800cfm
-Crane gold 1.7 rockers
-Gm roller lifters
-Comp 930 valve springs
-Cam specs hyd roller
lobe lift adv .050" 0.200"
int
0.365" 287 228 146
0.375" 290 230 150
exh
0.354" 296 236 155
ICL=106
ECL=118
lobe=112
-Melling select series HV oil pump
-8qt marine oil pan
-merc thunderbolt ignition
-Stainless marine exhaust manifolds, 6" taller risers, vertical part of the riser extended 4" to silent choice diverters.
-Bearing clearances: mains 0.0031"(number 5=0.0039"), rods 0.0029".
-Piston to wall clearance: 0.0065"
JaniH is offline
Old 10-14-2020 | 07:49 AM
  #206
TomZ's Avatar
Use a ARP2000 rod bolt. The L19 rod bolt requires careful handling and cannot be exposed to moisture. You can't even touch it with your skin.
TomZ is offline
Old 10-14-2020 | 02:36 PM
  #207
Is it really that critical, sound crazy.
JaniH is offline
Old 10-14-2020 | 02:56 PM
  #208
TomZ's Avatar
Here's a link explaining everything you'd ever want to know about selecting rod bolts:
https://www.speed-talk.com/forum/viewtopic.php?t=34831
For what you're doing you could even get away with the 8740 bolt/screw that comes standard with your rods and probably save $100.
TomZ is offline
Old 10-14-2020 | 03:00 PM
  #209
TomZ's Avatar
From that post on Speed Talk:
ARP 8740 chrome moly “connecting rod” bolt:
Yield strength = 180,000 psi
Tensile strength = 200,000 psi
Cost = $120.00 per set of 16 at Summit Racing Equipment, or about $8.00 each.
ARP 2000 “connecting rod” bolt:
Tensile strength = 220,000 psi
ARP 2000 rod bolt material has twice the fatigue life of 8740 chrome moly rod bolt material.
Cost = $200.00 per set of 16 at Summit Racing Equipment, or about $13.00 each.
ARP L19 “connecting rod” bolt:
Yield strength = 200,000 psi
Tensile strength = 260,000 psi
ARP L19 rod bolt material is subject to hydrogen embrittlement, and stress corrosion. It also cannot be exposed to any moisture, including sweat and/or condensation.
Looking at the L19 description, you can see that exposure to moisture is a problem for the material. Your oil will eventually contain some moisture. It has the capability of becoming a problem. A rod bolt and cap letting lose is never pretty.
TomZ is offline
Old 10-14-2020 | 04:15 PM
  #210
Looking at the L19 description, you can see that exposure to moisture is a problem for the material. Your oil will eventually contain some moisture. It has the capability of become a problem. A rod bolt and cap letting lose is never pretty.
ARP 2000 sounds great solution! what would be the arp part number for EAGLE H-beam 7/16" cap screw rods bolts, arp-20000?. what torque specs i should use with arp2000 bolts, rod manufacturer or bolt manufacturer?
JaniH is offline
