Bilge Paint
Old 04-01-2019 | 06:32 PM
cigrocket's Avatar
Professional white rustoleum and valspar hardner. Excellent results and lower price!! I have used awl grip and Bilgekote in the past wasn’t as happy. Prep is key! Good luck
cigrocket is offline
Old 04-01-2019 | 06:56 PM
Originally Posted by phragle
I have used rustoleum with hardner on 2 seperate boats with good results
Actually last time I used the rustoleum farm implement gloss white with hardner,,,,, Guy at tractor supply said it would stand up to just about anything....
phragle is offline
Old 04-01-2019 | 07:08 PM
Now you tell me.
ph1971 is offline
Old 04-01-2019 | 09:02 PM
I used the sherwin williams macropoxy and am very happy brush or roll on goes on great flattens out no brush marks 1 coat. Gal of epoxy and gal hardener about $200. Enough to do 2-3 bilges
chris302 is offline
Old 04-01-2019 | 09:20 PM
chris302 is offline
Old 04-01-2019 | 09:26 PM
chris302 is offline
Old 04-02-2019 | 11:59 AM
I did interlux Bilge coat in the Fountain about 3 years ago. Holding up great
IslandFever is offline
Old 04-02-2019 | 05:40 PM
I have used rustoleum with Valspar enamel hardener (you must use that hardener) for almost a decade now. The stuff is great, cheap and easy to find. If you want the off-white fiberglass color in a lot of boats just mix 3qts of white with a qt of their almond. Another thing, the cans of spray paint at depot matches the gallon perfect. Make touch ups easier.
Only one draw back, If you mix the Rustoleum with the hardener you MUST NOT SPRAY IT unless you have a full body suit and a fresh air supply. There is something in the hardener that when sprayed can kill you if inhaled and can even be absorbed through the skin. It only applies to spraying.
f_inscreenname is offline
Old 04-03-2019 | 06:53 AM
https://www.zoro.com/rust-oleum-alky...CABEgIjyfD_BwE
i used rust oluem high performance paint..ised years ago
glass work done by dave goodmen
flashgordon is offline
Old 04-03-2019 | 07:54 AM
I used Rustoleum with Valspar enamel hardener as well.. Brushed on..
The brush strokes all but disappeared and the paint has held up GREAT !
Excellent budget friendly option...
Boatally Insane is offline
