Bilge Paint
Old 04-01-2019 | 11:58 AM
Default Bilge Paint
I have the engine out of my 99 Baja and thought it would be nice to paint the Bilge/Engine room. My first idea was to go with AwlGrip, but by the time I purchase the primer, paint, activators and reducers it is going to be over $500. Does anyone have any recommendations for a product that works? The bilge is white.
Thanks!
Pete
Peterkvs is offline
Old 04-01-2019 | 12:35 PM
I did awlgrip brushable in mine and I think my total was $300-$350. You might shop around. The finish is sweet by the way. If you apply it with a roller you must brush it flat or it makes air bubbles.
ph1971 is offline
Old 04-01-2019 | 12:41 PM
F-2 Speedy's Avatar
Rustolium white enamel , inexpensive and holds up, did my 33 Outlaw years ago
F-2 Speedy is offline
Old 04-01-2019 | 01:32 PM
Yup. Engines hide most of the paintwork in the bilge anyway. And definately white. When doing headstand next to engine looking for that tool or part, you need all the light you can get.
dereknkathy is offline
Old 04-01-2019 | 01:55 PM
I used rustoleum professional grade with valspar hardener. Very happy with the results
Crude Intentions is offline
Old 04-01-2019 | 02:02 PM
Guys, Thanks for the replies. Did you apply the rustoleum with a brush, roller or spray? Did you Sand, Scuff, prime etc? Any advice on application methods would be greatly appreciated
Peterkvs is offline
Old 04-01-2019 | 02:27 PM
Interlux Bilgekote is nice stuff too. Just did my Sunny 288 while motor was out. Apply it with a brush and/or roller.
ccrder1 is offline
Old 04-01-2019 | 02:35 PM
Clean really well. Degrease. Sand/scuff. Clean again. Roll/brush paint on. Prep is 95% of paint work. Prepped right you’ll love it. Don’t prep right it’ll be a mess.
Old 04-01-2019 | 04:49 PM
A little trick with Rustoleum, if you thin it a little with Acetone, it will flatten out real well and look great. I have been using Rustoleum for a lot of projects lately, I've sprayed it and brushed it and the finishes are amazing when you cut it.
ThisIsLivin is offline
Old 04-01-2019 | 05:56 PM
I have used rustoleum with hardner on 2 seperate boats with good results
phragle is offline
