Idiling the engine in a boat >
Old 05-13-2022 | 07:16 AM
Active Streak: 30 Days
As you make adjustment to the mixture screws, give it a few seconds to find the new setting, then adjust the idle speed screw (throttle plate) to the recommended idle speed, usually around 700-800 RPM in gear. Repeat until motor is happy with vacuum and idle.
Helmwurst is offline
Old 05-13-2022 | 07:59 AM
great tip...but what shuld be my starting point..i know they cant be fully closed..screw in just enough so the engine can run or somthing difrent
Zole is offline
Old 05-13-2022 | 08:02 AM
and what should be my happy vacum..how much hg or -psi
Zole is offline
Old 05-13-2022 | 08:31 AM
Wally's Avatar
Were doomed!
Holley Carb Adjustment
-Wally
Wally is offline
Old 05-13-2022 | 10:26 AM
Originally Posted by Wally
I read that allready...the thing that happens to me is wen i find the highest vacum in idle and i put it in gear so that the propeler turns it creates big load and my engine shuts down..im thinking my idle mixture is too lean so ill have to set a more richer mixture next time...never the less yo all are my think thank and i thank you for your patience learning me how to properly toon USA engines.
Zole is offline
Old 05-13-2022 | 12:59 PM
Might be a problem with ignition system.
TexomaPowerboater is offline
Old 05-13-2022 | 01:16 PM
Wally's Avatar
Were doomed!
That is true....once had a problem where the engine idles great in neutral but always died when i put it into gear. Spent countless hours swapping parts. Turned out it was an advance spring inside the distributor that broke!
-Wally
Wally is offline
Old 05-13-2022 | 01:36 PM
I've put it 8 degrees advance but i didn't chek the distributer...ill do that but it's allmost 9 oclock in the evening so it is night and i can't test it now.ill do it tomorow.
Zole is offline
Old 05-13-2022 | 05:02 PM
Is it an alpha or bravo drive? Alpha uses a shift interrupter that interrupts the ignition.
liberator221 is offline
Old 05-13-2022 | 08:17 PM
That has nothing to do with idle.
1BIGJIM is offline
