Idiling the engine in a boat >
Old 05-24-2022 | 02:08 PM
  #41
SB
Gap plugs to .035 “. No higher than .040” or i’ll fly out there and poke you in your eyes. lolol
SB is offline
Old 05-24-2022 | 02:29 PM
  #42
Roger that..over and aut
Zole is offline
Old 05-25-2022 | 09:42 PM
  #43
Europa calling for help...com in SB
Zole is offline
Old 06-08-2022 | 01:27 PM
  #44
can i ask you for advice..it is regarding the mercruzer 7.4 i can't get it to work...i have a new simptom..every other cilindar is respondind on a drop cilindar test...so the 1 is responding the 2 is not the 3 is the 4 is not and so on...is that a simptom for somthing...tnx
Zole is offline
Old 06-08-2022 | 01:45 PM
  #45
F-2 Speedy's Avatar
what do you mean drop cylinder test, how is this being performed
F-2 Speedy is offline
Old 06-08-2022 | 02:17 PM
  #46
i turn on the engine and then start tu pull off cables from spark plugs and listen to the engine change rpm...on 4 cilinders he does not change rpm..
Zole is offline
Old 06-08-2022 | 03:03 PM
  #47
F-2 Speedy's Avatar
do you have it wired like this
Old 06-08-2022 | 09:06 PM
  #48
jes i have the firing order on the manifold....and it is a mercruzer
Zole is offline
Old 06-09-2022 | 11:09 AM
  #49
problem solved...it was the carb
Zole is offline
