Mercury 500 EFI Noise..
I missed the 50 hours of run time before the noise........Lux I think Johnson makes a replacement lifter for the 500............https://johnsonlifters.com/
Hello
Thank you all for your valuable help
The weather being less cold, I went to the hall.
I removed the valve covers, the spark plugs.
With strong lighting, I saw on of the lifters are the model with the tie bar !!!!
The valve of cylinder n° 2 has the most gap
https://dai.ly/k77bofoxdFlnmtCjfOu
Hello
Hello
with that being said…your video looks like there is up in down play. Not sure that looks normal.
You know I would go through and readjust them all and fire the motor up, see how it sounds.
Sutphen does have a good comment, sure doesn't look like any oil in the top end, what is up with that? What was/is your oil pressure at idle and running?
Hello
I would at a minumum, remove that rocker and pushrod and inspect them for damage.
