Drive Not Lifting When in Water >
Old 05-28-2007 | 07:48 PM
Craney's Avatar
Default Drive Not Lifting When in Water
The starboard drive will not trim up when in gear in the water.It will trim up and down when on the trailer and out of gear in the water.When you start moving it doesnt trim up,the motor is working fine with new oil?
Craney is offline
Old 05-28-2007 | 07:57 PM
What kind of shifters do you have?
spunky is offline
Old 05-29-2007 | 09:17 PM
kaama82's Avatar
The drive won't trim up when on plane? of just idling?
kaama82 is offline
Old 05-30-2007 | 04:18 AM
Craney's Avatar
When its on plane and idling put it back on the trailer it moves up down.
Craney is offline
Old 05-30-2007 | 05:00 PM
kaama82's Avatar
Has the trim hoses, from the trim pump to the trim cylinder ever been removed by yourself or maybe a previous owner?
kaama82 is offline
Old 05-30-2007 | 07:41 PM
I had the same issue when I got my boat. The trim worked on the trailer and at the dock, but once I put it in gear the drive would not trim up. For me it was a simple fix, just swapped place on the trim lines on the pump.
bl
badluck is offline
Old 05-30-2007 | 08:09 PM
kaama82's Avatar
That's where I was headed. The trim pump has a low pressure and high pressure side. The high pressure side is for lifting the drive up.
kaama82 is offline
Old 05-30-2007 | 08:45 PM
Craney's Avatar
Yes the the trim cylinder was replaced.
Craney is offline
Old 05-30-2007 | 09:03 PM
kaama82's Avatar
I would check your lines to make sure they didn't get put on backwards.
kaama82 is offline
Old 05-31-2007 | 08:44 AM
hoozeyurdaddy's Avatar
if the lines are correct, was it a new cylinder or a used one?
if used the check valves inside the cylinder could be bad, and not able to hold the pressure of the sys. when put into gear.
hoozeyurdaddy is offline
slik22
Drives and Lower Units
2
07-23-2008 02:00 PM
plumbers crack
6
11-25-2005 07:06 PM
Velocity Tom
07-16-2003 10:13 AM
Waterfoul
04-17-2003 08:01 PM
DRTOBE
5
04-08-2003 12:22 PM
