Changing Drive Oil >
Changing Drive Oil
Changing Drive Oil
Old 06-06-2007 | 08:05 AM
aquatictherapy's Avatar
Default Changing Drive Oil
When I change the drive oil, the oil in the reservoir does not drain out. Is it suppose to?
Scott
aquatictherapy is offline
Old 06-06-2007 | 08:29 AM
Mine does. Your supply line may be clogged. When you fix it clean your reservoir out. Mine accumulates sludge for some reason.
kennyo is offline
Old 06-06-2007 | 10:04 AM
Downtown42's Avatar
Try loosen/open cover on resevoir, will flow better. Make sure both plugs removed off drive.
Downtown42 is offline
Old 06-06-2007 | 10:06 PM
tblrklakemo's Avatar
SeaRay Sundancer
R U sure it isnt draining out with the cap off and both plugs undone? Sometimes that sludge can stick to the sides and make it look kinda full. If it is full loosen the elastic strap holding it to the engine and turn upside down into a platic cup. Then take it off the motor, disconect from the tube, and put a little bit of gasoline in there and swish it around and clean it out. Liquid should flow out the bottom of the tank. If that doesnt let it drain than your tube from the tank to the drive might be clogged.
tblrklakemo is offline
Old 06-07-2007 | 11:26 AM
Mine drains very slowly. I know that the hose and valve are clear.
Rene
oldandtired is offline
Rebel_Heart
4
10-10-2006 08:06 PM
pondrocket
Fountain
5
08-09-2004 08:00 PM
bn
4
05-22-2002 08:33 PM
magnuman
1
04-21-2002 02:43 AM
BAJA WILL
3
04-16-2002 10:03 PM
