Trim Pump Just "Clicks" >
Old 06-15-2007 | 08:24 AM
Wally's Avatar
Were doomed!
if the motor is locked up you can try freeing it by tapping on it with the handle of a screwdriver while someone else hits the up/down buttons....
-Wally
Wally is offline
Old 06-16-2007 | 09:22 AM
hoozeyurdaddy's Avatar
I think the hammer idea is better than the screwdriver. there are 2 relays, chances of both bad are slim, probably motor or bad ground.
hoozeyurdaddy is offline
Old 06-16-2007 | 08:59 PM
we tried the hammer and still no luck...I will let you guys know what we find
myscarab30 is offline
Old 06-16-2007 | 10:30 PM
Von Bongo's Avatar
First check to see if a breaker popped. On my fountain if the breaker popped it would still click. Then its pretty easy to run a hot wire to it and see of the motor spins.
Von Bongo is offline
Old 06-17-2007 | 05:10 AM
Xray50's Avatar
Check for coroded post or switch. Mine was clicking. Spayed with WD40, cleaned and tightened. Also spayed trim switch on throttle with WD40. Clicking problem gone!
Xray50 is offline
bobo1
OPA/The Jersey Boyz
0
04-23-2008 07:36 PM
electrical1
11
11-09-2006 08:51 AM
HPJunkie
7
02-18-2003 07:49 AM
mikesufka
12-26-2002 11:23 AM
