Trim Sender and Limiter????
hoozeyurdaddy,
The reason they had to be replaced was because the fine coil of copper wire inside the units would eventually break from the arm that rides against it. Fresh water application. Why can't the wires be spliced together if they are made water proof?
Dave
Dave
If someone who knows how to seal those wires properly is doing the work, it shouldn't be a problem, but if its someone with a couple of butt connectors and a pair of crimpers, well?
that is a repair that I could never get away with on a customers boat, If you have done it this way, and have been successful, then your way obviously works. but with a 7/16 swivel socket on a 1/4 drive with an extension, the job can be done correctly without drive removal.
Hoozeyurdaddy,
I tried that on my boat, but was not able to get the 7/16 swivel socket on the upper bolt of the retainer. Is there something that I am missing? I would like to know for future reference!
