Charging System Problems >
Old 09-17-2007 | 05:52 AM
Default Charging System Problems
Last few times out I've noticed a problem with my charging sysytem. Sometimes my volt meter will peg at 16 volts! Very erratic. It will be OK for a while and then jump to over 16 volts. I know the gauge is working because at night when this happens the lights get very bright. It is not the one wire alternator. What do you guys think? Time for a new one, can it be rebuilt, could it be something else. It is the original one on the boat from 1986.
Thanks, Dave
David Stotz is offline
Old 09-17-2007 | 01:38 PM
monstaaa's Avatar
could have an internal regulator problem.
monstaaa is offline
Old 09-17-2007 | 01:46 PM
Reed Jensen's Avatar
Ditto... internal regulator problem is your best bet. On some generators there is a "monitor wire" that goes to the electical system downstream from the alternator to monitor the voltage level. If that is shorted the regulator won't get a signal and could let the voltage go wild. This is not very likely. I think your regulator is toast.
Reed Jensen is offline
Old 09-17-2007 | 04:08 PM
OK, Thanks. I take it the regulator is inside the alternator. Is it replaceable or do I buy a new alternator.
Thanks, Dave
Old 09-17-2007 | 04:09 PM
I just realized I posted this in the wrong forum!
Old 09-17-2007 | 04:52 PM
Turbojack's Avatar
On one of my boats I had a alt that had built in regulator. I think the regulator went bad. I was able to buy a new 1 wire alt. cheaper then getting a replacement regular. I changed alt. out, capped off the extra wires and worked perfect ever since.
Turbojack is offline
Old 09-18-2007 | 05:05 AM
Thanks one and all for the help!
cloudmaster_321
14
05-27-2005 10:58 PM
tmthunder
2
08-27-2004 09:48 PM
38cigmike
1
08-03-2004 01:05 PM
pro design
3
01-10-2003 11:53 PM
Bajaforce
2
01-10-2003 09:27 AM
