remote oiling for bravo 1 >
Old 02-29-2008 | 07:33 PM
That sums it up pretty good. Thanks for all the info I beleave I got it.
team Tickfaw is offline
Old 03-01-2008 | 11:37 AM
Mr Gadgets's Avatar
Charter Member #601
Ok.. thanks Vinny.. lost track of my focus!!
Mr Gadgets is offline
Old 03-04-2008 | 03:09 PM
tblrklakemo's Avatar
SeaRay Sundancer
I remove my bottle when changing out the lube and clean the sludge out....then I blow a little air into the unconnected tube until I hear it come out the drive oil drain hole. This way i know the tube and bottle are clean and flowable. You will have to top off your drive lube bottle a couple times after running it.
tblrklakemo is offline
Old 03-04-2008 | 04:09 PM
Thanks this all really helps.
Old 01-27-2009 | 04:50 PM
sleek1's Avatar
Originally Posted by US1 Fountain
I have to remove, empty and clean my drive bottles every yr to get the sludge off the bottle bottom. Don't know what causes it as the drive lube is changed every yr and there is no water in the drives. The sludge could get thick enough to hold the float up from sounding the alarm if it where to get low on oil.
When you unscrew the wiring harness (bottom cap) do you use a torque wrench to put it back on or just a wrench and rule of thumb?
sleek1 is offline
Old 01-28-2009 | 01:01 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
I just unplug the 2 wires at the bottle and remove the bottle and hose as a whole. The push clip at the transom for the hose can be a trick to undo at times.
Just snug on the bottom cap if you do take it apart. But I almost never take it apart to clean because it's a pain to work inside the bottle getting the flaot clip on/off. I just put a little gas in it and shake it till it's clean and then drain the gas thru the hose to clean it out also. Usually takes a couple gas changes to get it clean.
Then let it dry real good before reinstalling.
US1 Fountain is offline
Old 01-28-2009 | 11:11 AM
sleek1's Avatar
Thanks for the pointer. I must have overlooked the disconnect at the bottom of the bottle.
sleek1 is offline
Ryan00TJ
4
01-23-2008 03:25 PM
cloudmaster_321
29
04-13-2007 12:55 PM
brent05
0
04-17-2006 08:27 PM
hpy540
3
03-19-2005 05:23 PM
bluewater7
5
08-31-2004 10:25 PM
