Gimbel Ring Removal >
Gimbel Ring Removal
Gimbel Ring Removal
Old 05-16-2008 | 11:21 AM
fastedy's Avatar
Default Gimbel Ring Removal
any threads on removing the Gimble Ring, motor is out do I need to remove assemble off the boat? Merc book that I have has no mention of the Gimbel.
Eddie
"If Things Seem Under Control, You're Not Going Fast Enough"
Mario Andretti
fastedy is offline
Old 05-16-2008 | 05:46 PM
sandman
If the motor is out, its easier to remove the the gimbel, gimbel housing and bell housing as a unit and refurbish it on a bench (bushings, seals, bellows etc) then reinstall it as a unit. Just finished mine. Good luck.........Casey
sandcraft is offline
Old 05-17-2008 | 04:40 AM
fastedy's Avatar
starting it today, are you talking abought the bushings in the bell and what seals, I do not see them in the kit?
Mario Andretti
fastedy is offline
Old 05-17-2008 | 09:14 PM
sandman
Mine is an old bravo 1 (1993) the bushings for the bell housing are in the gimbel ring as well as the lower pivot bushing. the upper pivot bushing is pressed into the gimbel housing. This bushing also has a seal. If you pull the transom assembly off you can inspect the mounting studs and bolts. Two of mine were corroded and actually broke apart. Also a source for water leakage. The exhaust block off plate was corroded enough to cause leakage. There is a large seal that fits between the gimbel housing and the outer transom. Also a good time to inspect the gimbel bearing and seal.
Old 05-18-2008 | 05:22 AM
fastedy's Avatar
Thanks, came to a halt yesterday, I do need the replace that metal bushion and the seal, It fell out with the swivel shaft, I will have to order it Monday
Mario Andretti
fastedy is offline
fastedy
Drives and Lower Units
1
05-15-2008 05:50 AM
checkmate DOH!!
8
07-03-2007 06:41 PM
lightspeed
Superboat
6
05-24-2006 02:15 PM
Fast Shafts
11-16-2005 07:15 AM
lightspeed
11-02-2005 07:10 AM
