Pros/Cons external water pickup >
Old 11-24-2008 | 02:17 PM
Default Pros/Cons external water pickup
My mechanic suggested I switch to an external water pickup. His feeling is the Bravo doesn't allow as much water to the impeller as an external unit. The Bravo water feed is 3/4", compared to the 1" water pump hose.
What are the pros/cons?? Thanks!
For what its worth the boat is a 24' Sunsation class 6 boat.
Fast Shafts is offline
Old 11-24-2008 | 04:13 PM
i have heard that you might lose a mph or 2 depending on the way it is mounted.
Perlmudder is offline
Old 11-24-2008 | 04:28 PM
I don't see why that would be a problem in a Class 6 boat. Don't you guys run relatively mild enigines? LWP on a Bravo should feed plenty of water to that engine. It will also be lower in the water for when you guys are running in the rough onthe course.
jeff1000man is offline
Old 11-24-2008 | 04:29 PM
What is your engine telling you ?????????
Is it overheating or is the waterpressure below 16 PSI ???
If not leave it .
DareDevil is offline
blownincome
Fountain
11
12-21-2021 08:19 PM
mookymonkey
20
03-25-2012 11:37 AM
socalstone
28
11-25-2008 09:02 PM
ohmthis
5
06-26-2007 06:33 PM
Montauk Crossbow
11-25-2002 08:07 PM
