need to update XR Drives ??
reading all the comments, it looks like i will be trying to use Max Machine Worx drives. From research for the price, it seems they are going to be the best choice at this time, unless someone has a better idea. I will be bringing the power down to about 850-900, but the torque is still there, it looks like the power is not the main issue on the drives, but the torque is the big factor.
I had no idea, before i purchased the motors and now i am stock with big power and not being able to use them like the way i wanted to, unless going to #6 drives, which are way over my head on the financial side.
Would love to hear more on Max Machine Worx from any one that has used them or heard of them.
Who on here treats XR gears?
Was curious on the cost.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
Hello group, i had purchased a set of XR Drives last summer and now i have updated the motors to 1000HP with lot's of torque and need to update the drives. Any suggestions? I know SSm#6 is the way to go, but the work that goes into it and moving the back seat and transmission gets very costly. Has anyone used anything different that would be a replacement of the Bravo drives, which will handle the torque and the power???
1000hp wow- really? Whats the build look like-?
Maybe you can step the blower boost down a bit with a larger pulley.
if you can pull down to around 900 you can use-
The Imco SCX- super strong
Teague platinum shaft- XR
You can have Teague rebuild your XR with his gears and shaft and Imco lower warranted for 1 YR with his engines its a very strong drive
Bmax
An NXT drive can likely handle 900
Yeah a #6 is the best choice- only a v-drive, or jet can handle more than a #6
OF all these options your best bet is probably a Teague mod, and a little less power.
Uncle Dave
And I forgot the very cool arneson drive- this to can withstand ridiculous power, and is THE most efficient drive.
the "Arneson principle" dictates the top half of the prop swing is a parasitic waste and eliminates it - with the props 3 to 9pm as the only part in the water- thereby reducing parasitic loss.
Downside- a giant exposed prop on a hydrauliclly actuated arm can kill towables, or skiing - the rooster tail is on par with a jet-o-vated equipped berkely on 5/8 UP - and can be considered dangerous for swimming etc. They make a guard for it, but it is what it is.
Uncle Dave
Uncle Dave
Bmax
Uncle Dave
Bmax
Uncle Dave
Mike wrote:
Hello Uncle, thanks for the info. Yes, we are going to change the boost from 7 lbs to around 4-5 and some other stuff, but the torque will still be there. At this time, we are planning on using the upper of Max Machine, i have lot's of good comments about them and for the price looks like what i can afford. Have you heard anthing else about the Max drives?
I have heard very good things about the b-max upper.
I guy named Quent has had Imco and Bmax and likes that B better.
He had it in back of a 900HP Tyler Crockett blown big block in a Lavey Sabre cat, and said it outlived the Imco considerably.
Right now hes got a 24ft LaveyCraft bowrider with an Ilmor 710 in it.- runs mid 90's
Send him a mail or look him up- waay cool guy & has first hand experience.
Uncle Dave
