#5 Drive oil.....
Old 01-31-2009 | 08:38 PM
HotPursuit's Avatar
Originally Posted by bob
I too would be curious oto hear of potential hp gains. I am though concerned about the negative of damaging a seal and as the drive cools while in the water it fills with seawater. I hear that can be real expensive since there is a limited amount of oil in the drive there is plenty of room for water.
Thats only a problem on the total dry sumps that run tanks in the boat and a pump on the engine.The second and third seal never see oil anyway. First seal faces in and the second and third seal face out.
Mercs drysumps still hold enough oil when idle to the top skeg. When you running it drops down to right above the nose cone. Not as fast as a total drysump but less tanks,hoses,pumps and water!!
I check mine after every hard day and so far no problems.
HotPursuit is offline
Old 01-31-2009 | 08:44 PM
HotPursuit's Avatar
Few shots of my conversion. Notice the #6 pump and filter is located in the nose cone.
Attached Thumbnails #5 Drive oil.....-dry-sump9.jpg   #5 Drive oil.....-dry-sump-7.jpg   #5 Drive oil.....-num6cut.jpg
Old 01-31-2009 | 08:52 PM
HotPursuit's Avatar
wet sump to dry with new skegs
Old 01-31-2009 | 09:51 PM
marinetrans's Avatar
Six drive gears hold up better w/just a spray of oil rather than submerged in oil we found.Gears submerged in oil had higher failure rates and the newer upper gear sets are nice.
marinetrans is offline
Old 02-01-2009 | 10:28 PM
HotPursuit's Avatar
I agree!!!
Old 02-13-2009 | 08:12 AM
CNC's Avatar
CNC
Ok, I've decided on Amsoil severe duty gear lube.. now which weight 75w-90 or 75w-110?? and why?
CNC is offline
Old 02-13-2009 | 09:00 AM
I heard 110 ,,,but i could not tell u why . ?!
Also heard LUCAS oil is not bad.
DareDevil is offline
Old 07-12-2009 | 07:22 PM
CNC's Avatar
CNC
Ok, I've decided on Amsoil severe duty gear lube.. now which weight 75w-90 or ?? and why?
I guess it's Amsoil 75w-110?? Where is the cheapest place to buy??
I need gallons (5) rather than quarts....
CNC is offline
Canada Jeff
Drives and Lower Units
10
07-19-2007 02:38 PM
jeff32
06-28-2006 08:48 AM
Superbabi
Superboat
5
02-16-2006 02:02 PM
Velocity Tom
07-16-2003 10:13 AM
RUSSSR1
2
06-20-2003 10:38 AM
