What Drive?
Old 08-19-2011 | 07:47 PM
  #101
Originally Posted by WAGS382
kjm5125
I am at the bay for the weekend, I will keep an eye out for roosters. If you see my 382 with a teal stripe buzz us and I'll get a vid with the go pro. Good luck with your project.
Sounds great and depending on how things go I'll be around the Casino or at the Bay.
kjm5125 is offline
Old 08-19-2011 | 07:51 PM
  #102
Default Transom Before
This picture really shows how everything clean up!
kjm5125 is offline
Old 08-19-2011 | 07:53 PM
  #103
Found another transom shot.
kjm5125 is offline
Old 08-19-2011 | 08:05 PM
  #104
Originally Posted by UrbanDisturbance
Awesome. I can't wait to do mine. That looks great. When you have time, can you post a side view to show how close the bottom of the standoff box is to the top of your step. Do you know if they had to lower or raise the original position of the engines?
I'll take a picture, it's about 1". The engines mounts were moved 2.5" forward. The concern we had, because of the Intercoolers, would we still have hatch clearance. As it turns out we had plenty of room.
kjm5125 is offline
Old 08-20-2011 | 08:07 PM
  #105
So, how was testing today?
A.O. Razor is offline
Old 08-21-2011 | 11:32 AM
  #106
Default Well..........
Somewhere within 15 minutes the port transmission failed and we limped back to the marina.
I contacted Rik and he said he will take care of it immediately.
What I learned in that short period of time, and I knew, is that the Arneson drives handle much different than the XR's. As I've heard, to get on plane, you need to find your "new sweet spot". Just when I thought I found my "sweet spot" is when I realized there was a problem.
Once it gets repaired and I'm back on the water and I get some good seat time, I know I will truly like the drives.
kjm5125 is offline
Old 08-21-2011 | 04:05 PM
  #107
Wow, that's a bit of a bummer. Any idea what happened?
Glad to hear you are still optimistic about your new drives.
Old 08-21-2011 | 07:04 PM
  #108
A seal failed....yea, needless to say I was pretty bummed.
kjm5125 is offline
Old 08-21-2011 | 07:29 PM
  #109
Were these used transmissions? How long did it take to get on plane or it broke before you got on plane?
waconda is offline
Old 08-21-2011 | 08:03 PM
  #110
New transmissions and I don't know when the failure happened.
kjm5125 is offline
