What Drive?
Old 05-19-2011 | 11:39 AM
t500hps's Avatar
21 and 42 footers
Originally Posted by SS930
I agree the Arneson is the clear way to go, but once you add in props and some applications having to fill the transom step, it can become a little more expensive of an option. If the money is of no concern, I'd go with the Arnesons.
Regardless, doing some type of 'conversion' BEFORE the factory bravo goes south is the smart way to go... at least this way you can recoupe some your money by selling it while it still has some value.
If your upgrading power enough to where you're considering Arnesons.......your changing props anyway.
t500hps is offline
Old 05-19-2011 | 12:04 PM
Originally Posted by Rik
99% of applications do not have any issues with a notch! Also you have to purchase propellers regardless of which out drive you use and we offer two different propeller hub choices, Bravo and Speedmaster.
What is the pros and cons of each prop? IF you have the Arnerson surface drive.
Wildman_grafix is offline
Old 05-19-2011 | 02:20 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Not so much specific to an Arneson but the propellers in general are very much different from one another.
Rake: The Bravo styles have much much more.
Diameter: The Speed masters have the edge by far
Bite: Speed masters
Cost: Bravo's
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 05-19-2011 | 03:03 PM
Thanks RIK,
So if someone is think of or doing the bravo conversion on a boat that hasn't been done how do you go about determining which style to go with?
Old 05-19-2011 | 04:17 PM
Rik's Avatar
Rik
Size and power.. Smaller boats are best for the "Bravo" style housing and the larger boats run best with the cleavers.
Rik is offline
Old 05-19-2011 | 07:52 PM
It appears most think Arnerson is the way to go. Does anyone have any negative points?
kjm5125 is offline
Old 05-21-2011 | 10:02 AM
By that, do you mean running bravo style props on an arnie, eh?
Never seen that before. How is that done? Sorry if this is a stupid question, just can't figure it out.
A.O. Razor is offline
Old 05-21-2011 | 06:02 PM
There really are no negatives to the arneson. There are some minor negatives to "surface drives with cleaver style props" but nothing specific to the arneson. ALL new, fast, powerboats run surface drives and there is a reason obviosly!
offshorexcursion is offline
Old 05-21-2011 | 08:16 PM
Thumbs up
Excursion! how are the Arnesons coming along on your boat? have you had a chance to run them yet?
abones is offline
Old 05-21-2011 | 09:59 PM
Rik's Avatar
Rik
Yes, the benefits of one is not the same on both sizes, mostly due to the cost relationship as well as boat size and HP
Rik is offline
