What Drive?
Old 10-15-2011 | 03:07 PM
  #191
Originally Posted by kjm5125
I've concentrated on finding the best tab and drive positions to quickly get on plane. I was running consistently in the low 80's. The best I saw was a little over 84 GPS and I know there is more there. With the XR's the best I ever got was 83 GPS.
What is the RPM difference between the 83mph with the B1 and the 84mph with the Arneson, and do you think there is 7 to 8 mph left in it with propping?
waconda is offline
Old 10-17-2011 | 08:45 PM
  #192
At 84, I was all over the limiters @ 5,500 rpm's simply because I had the drives too high. This boat runs best in a 2' chop and I was running 84 in fairly flat conditions. I believe 90 is attainable, but I'll have to wait until next year. When I hit 83 with the XR's, I was at about 5,400 rpm's and it took some effort to get there. When I hit 84, I was not even trying for top end.
kjm5125 is offline
Old 10-17-2011 | 09:15 PM
  #193
Sounds like you will easily get there for sure!
offshorexcursion is offline
Old 10-18-2011 | 05:32 PM
  #194
So will it take a different prop or do you think it about right now?
waconda is offline
Old 10-18-2011 | 07:48 PM
  #195
I'm not 100% sure if it's the right prop. I'll try again next year and check the prop slip. There is no doubt I need to lower the drives.
kjm5125 is offline
Old 10-19-2011 | 01:17 PM
  #196
What makes you think you need to lower the drives? What's the issue?
UrbanDisturbance is offline
Old 10-19-2011 | 02:51 PM
  #197
How are the drives lowered, and how much adjustment is possible? Do you need to move the engines then?
A.O. Razor is offline
Old 10-19-2011 | 08:48 PM
  #198
OK, I wasn't clear, I need to trim the drives lower and just get more of the props in the water. The actual engine and drive position is just fine.
kjm5125 is offline
Old 10-20-2011 | 08:11 AM
  #199
You also could try props with more diameter and rake.
kvogt is offline
Old 10-20-2011 | 11:26 AM
  #200
I don't think diameter is the issue. 5 blade 17" should be more than plenty on a 38' boat. But something like 20 dgr rake and 32" pitch, maybe even in a 16.5" dia.
6 blades could be an option too.
Have you talked to Bblades about testing? As you know, Brett has the Hering test program now.
Oh well, there's a whole winter for all of us to think about props.
And I guess winter's here, got another bunch of x-mas catalogues today. Now... what do I want for x-mas? Hmmmm
