What Drive?
Old 08-02-2011 | 11:05 AM
  #81
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
From the photo perspective, kinda an optical illusion
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 08-02-2011 | 06:39 PM
  #82
Originally Posted by A.O. Razor
Looks sweet.
Rik. Are the extension boxes supposed to sit below the notch? It looks like they do.
More than an inch above.
kjm5125 is offline
Old 08-02-2011 | 07:41 PM
  #83
Ah, thought so.
Any idea about what kind of props you will run?
A.O. Razor is offline
Old 08-02-2011 | 08:36 PM
  #84
Hering-17x31
kjm5125 is offline
Old 08-03-2011 | 06:53 AM
  #85
Hering-17x31
4 or 5 blades? What horsepower do you have? I'm curious, as I plan on putting Arnesons on my 1994, single notched transom, 38ft Cigarette Top Gun in the future. It wieghts 11,500lbs dry. I have one ASD7M drive in the Garage, just saving up for the 2nd. Can't wait to see your results. Don't forget to show some video when you go out!
UrbanDisturbance is offline
Old 08-03-2011 | 08:13 AM
  #86
5 blade Herings, stock 575's with coolers, hp 625-650 estimated
More pictures and video to come.
kjm5125 is offline
Old 08-08-2011 | 07:42 PM
  #87
A few more pictures. The transom cleans up real nice!
I went with the Hardin Strainers from CP Performance.
The end is very near!
Attached Thumbnails What Drive?-img00245-20110807-1308.jpg   What Drive?-img00237-20110807-1218.jpg
kjm5125 is offline
Old 08-08-2011 | 07:45 PM
  #88
Default XR gear
These picture is why I decided to go with Arnesons. This was the worst of the gears.
Attached Thumbnails What Drive?-img00242-20110807-1304.jpg   What Drive?-img00241-20110807-1303.jpg   What Drive?-img00244-20110807-1304.jpg
kjm5125 is offline
Old 08-09-2011 | 05:17 AM
  #89
Looking good
And why every hi-po B1 owner should consider it. Over time, that is money out the window right there.
Are you running 1,56 gears in the arnies? I assume you ran 1,5 in the B1's. What pitch/rpm/speed did you run with the B1's?
Looking forward to see some numbers.
Old 08-10-2011 | 06:59 PM
  #90
1.56 gears in the Arnesons and 1.5 in the XR's. I was running 5 blade Hydromotives - 15-1/2 x 29 (P-5). The best speed was 83.1 GPS @ 5,300 rpm's.
kjm5125 is offline
