IMCO SCX4 Single V Hull >
Old 11-02-2014 | 11:01 AM
Originally Posted by pro27
Total new set up been working on it for a while now.New Whippled 525 EFI IMCO SCX4 Merc 5 blade clever cnc,had it to 100 mph,lowered case went out today got to 102 mph at 5550 RPM.Think there might be more will keep informed[ATTACH=CONFIG]531848[/ATTACH]
Does it have a torque tab built into it ?
575cat is offline
Old 11-02-2014 | 11:44 AM
It does now IMCO put it on for my application, and it needs it.
pro27 is offline
Old 11-02-2014 | 04:33 PM
Mine had quite an arch to it I ground a little off .
575cat is offline
Old 11-02-2014 | 09:17 PM
Fender holder by Progression
pro27 is offline
Old 11-09-2014 | 09:36 AM
offthefront's Avatar
Yes prop shaft was 2" above bottom lowered 1/2" slip went down speed went up,going to try a little more to see what happens,also boat ran much better more control.
So .....this was standard X dimension with Bravo drive and the X4 changed the X by 4" and then you lowered it 1/2" ....so ... -3 1/2" ? ....
offthefront is offline
Old 11-09-2014 | 12:18 PM
No X dim was raised @3" before gear case was installed did this because its easier to come down with spacers then go up later on prop shaft approx 1-1/2" above bottom now,shaft was below bottom of boat with bravo drive not sure exact # ,scx4 drive is actually a surface drive
pro27 is offline
