Another oil question >
Old 04-06-2017 | 12:19 PM
Knot 4 Me's Avatar
Originally Posted by Tractionless
Curious to know why owners are using the Amsoil Severe Gear, which is a land machine based product over Amsoil's Synthetic Marine Gear Lube?
75/110 vs. 80/90 is my guess. More cushion for da pushin'.
Knot 4 Me is offline
Old 04-06-2017 | 02:33 PM
HOw long have you been running it and what's your opinions on its performance? Thanks
Ive only ran it last season, as it was my first season with the new to me boat and it seems fine to me. I'm over powering my XR's with IMCO lowers by a good amount like everyone else and I don't expect it to help save me from that but I'm planning on running it again this year.
I also have the trick billet aluminum top caps from Max Machine Works on the uppers and have drive temp gauges as well. One drive had a stock finned cap when I bought it and it always ran 20* hotter than the drive with the billet cap on it....put a new billet cap on that one so they match and viola the drive temps are the same now.
TooLateVTEC is offline
Old 04-06-2017 | 02:36 PM
NEO here. Same setup as above (Drive temp gauges, wags billet internally cooled caps, external showers), with addition of drive guardians.
Eliminated572 is offline
Old 04-06-2017 | 04:19 PM
I always thought Redline was the $hit, expensive and good, their marketing certainly makes it seem like a good choice.
Film thickness greater than an SAE 75W250, yet low fluid friction like 75W90
I bought a 5 gallon bucket in 2015 of the heavy shockproof.
My drive guy says it has no shear strength which Redline vehemently disagrees with.
These lower gears were new 4 years ago.:
Have to be replaced because of wear and unable to shim them.
Surveyor says improper shimming, drive guy says wear and tear... who knows.
Plus the prop shaft sheared right off:
Going with this now:
Chris where do you get the NEO stuff ?
ICDEDPPL is offline
Old 04-06-2017 | 04:50 PM
This is interesting. My old style XR upper has a flat top cap. Not many are running drive temp gauges for real comparisons. Do you have drive showers? Is this cap an easy bolt on? BTW, I use the Mercury HP Gear Lube.
thirdchildhood is offline
Old 04-07-2017 | 06:59 AM
Knot 4 Me's Avatar
Bravo Shop carries NEO.
Old 04-07-2017 | 07:20 AM
Good deal, should be just fine in all OE Bravo1's w/external showers behind 7.4 LX MPI Mercs Then.
Curious to know what goes into installing drive temp. Gauges?
Tractionless is offline
Old 04-07-2017 | 08:56 AM
seafordguy's Avatar
I use the Merc Stuff. But I'm probably not on the ragged edge of Bravo use at 565HP....
seafordguy is offline
Old 04-07-2017 | 09:12 AM
F-2 Speedy's Avatar
Brad Penn 20-50 semi synthetic or VR1 20-50 full syn ??
F-2 Speedy is offline
Old 04-07-2017 | 09:20 AM
In the drive??
