Still rattling
Old 08-21-2018 | 05:49 PM
  #111
35fountain's Avatar
New update: NO MORE NOISE....as long as i leave the shift fork out..lol check it out
NOW WHAT ?
35fountain is offline
Old 08-21-2018 | 05:52 PM
  #112
This is not meant to solve your problems but to give a little insight.
​https://www.riverdavesplace.com/forums/threads/max-machine-worx-drive-education.188298/#post-3076273​​​​​​
justfishing is offline
Old 08-21-2018 | 05:59 PM
  #113
35fountain's Avatar
https://www.riverdavesplace.com/foru...​​
Good information Thanks!
Old 08-22-2018 | 04:09 PM
  #114
35fountain's Avatar
When installing the input shaft assembly you must line up the marks on the gears for the timing + top - bottom or - top + bottom.. I was starting to put the cam assembly back in and noticed the - + symbol on the top gear but nothing on the bottom gear. Shouldn't they line up even though they turn in opposite directions. Maybe a cause of my shift cam rattle?
Old 08-22-2018 | 04:20 PM
  #115
Yes they should line up. It would cause shifting issues if they’re not lined up.
IGetWet is offline
Old 08-22-2018 | 06:36 PM
  #116
US1 Fountain's Avatar
Ginger or Mary Ann?
The lines on the gears should be aligned with the 2 marks on the case right in front of the shift shaft at top and bottom. Do you have a bravo service manual?
US1 Fountain is offline
Old 08-22-2018 | 06:53 PM
  #117
35fountain's Avatar
yes i have the manual and i know the procedure., That + - mark does.t look right to me in the photo..
Old 08-22-2018 | 07:31 PM
  #118
wheres the +/- mark on the bottom gear?
sutphen 30 is offline
Old 08-22-2018 | 07:55 PM
  #119
35fountain's Avatar
Got Me? That's what i'm saying SO before i remove the drive I am going to click the engine a few times to see if they align????
This is a learning experience for me....one thing after another!
Old 08-22-2018 | 08:03 PM
  #120
just pull the drive,loosen the spanner nut and spin the lower gear till they line up.put it all back together and go boating.
