XR to SCX, quick question... >
Old 10-22-2018 | 08:02 PM
Quote below is from IMCO installation manual.
9. SCX Drive is 19 7/8” from crankshaft center line to prop shaft center line (2” shorter than standard Bravo). SCX4 Drive is 17 7/8” from crankshaft center line to propshaft center line (4” shorter than standard Bravo).
I am 100% sure you are WRONG.
SCX upper is 2" shorter.
99silvergts is offline
Old 10-22-2018 | 10:36 PM
If a SCX upper was indeed shorter, you wouldn’t be able to use a SC or merc lower on it, The vertical shaft would be too long, which isn’t the case
JaayTeee is offline
Old 10-22-2018 | 10:40 PM
If a SCX upper was indeed shorter, you wouldn’t be able to use a SC or merc lower on it, The vertical shaft would be too long, since you can run these, they must be the same
JaayTeee is offline
Old 10-23-2018 | 07:07 AM
This is my set up.
IMCO SCX upper standard SC lower with standard vertical shaft. Propshaft is 2" higher than standard Mercury XR.
If you want a real answer to your question and not a bunch of guesses, call Fred at IMCO.
Old 10-23-2018 | 09:19 AM
SCX-4 upper is same dimensions as scx except for the cavitation plate that is bent up (lower to upper bolt pattern also different) to allow for the -4 lower prop clearance. The lowers are the difference between them. But yes a scx with a scx lower or a scx with a -2 sportmaster or -2 sc lower make the same x-dimension as a bravo with a -2 lower.
IGetWet is offline
Old 10-23-2018 | 09:20 AM
Originally Posted by 99silvergts
This is my set up.
Those are -2 lowers pictured, not standard lowers
correction: Those are standard lowers, angle of cav plate tricked me. So your setup is the same X-dim as a standard bravo setup.
IGetWet is offline
Old 10-23-2018 | 11:40 AM
I was just talking to jeff Harris to confirm. He said the scx4 is -2 in the upper -2 in the lower. Regular scx upper and lower is -0 in the upper -2 in the lower.
dsmawd350 is offline
Old 10-23-2018 | 11:46 AM
But in any case silvergts is wrong lol
Old 10-25-2018 | 09:20 AM
Don’t want to beat a dead horse here but the scx-4 upper is the same dimensions as the scx (obviously the splash plate is different). Otherwise it would not fit in the gimbal ring. The scx-4 lower is 2” shorter than a scx lower, which is 2” shorter than a standard bravo/sc lower
IGetWet is offline
Old 10-27-2018 | 01:47 PM
I did the conversion last year and checked with imco 2 times.
The SCX upper is the same height.
outlw36 is offline
