SSM3 oil leak
Old 11-10-2021 | 06:12 AM
resurrected's Avatar
Yes it will just slide out, be gentle with the alignment of the cardan joint through the helmet, its pretty tight.
Can't help with the lock nut.
resurrected is offline
Old 11-10-2021 | 06:31 AM
Active Streak: 30 Days
Is there a number etched or stamped on the lock?If so, you can call them and they will get you a key. That drive is heavy, better use a lift of some sort.
Helmwurst is offline
Old 11-10-2021 | 06:39 PM
scippy's Avatar
Ready to pull the drive, but does the trim cylinder need to be removed?.....I found the key to unlock Mcgard lock.
scippy is offline
Old 11-11-2021 | 06:22 AM
The trim rams don't need to be removed, I just loosen them off so they are completely clear of the drive. And definitely use a lift.
When re-installing the drive, lubricate the studs on the bell housing with oil and torque to 80ft.lbs.
Old 11-11-2021 | 10:10 AM
scippy's Avatar
Thanks for the great advice!.....I have a engine hoist ready.....besides the new oil hoses I ordered new gaskets between the drive and bell housing anything
else typically done at this point?..............
scippy is offline
Old 11-11-2021 | 11:01 AM
You're welcome!
I would take the opportunity to inspect everything, bellows, tail-stock seal, universals and anything else that is around there that doesn't get looked at close, regularly.
Make sure that no minors are present while the hose is being installed, it can be challenging which may lead to colorful language!
Old 11-11-2021 | 02:33 PM
scippy's Avatar
You're welcome!
What's amazing is really no u-tube video's of 3's 3a's V's etc; etc; mostly Bravo's which is a kinda different approach since they don't have a transmission to deal with oil hoses and what not.
Wish there was video of the cardan joint thru the Helmut process.....I need some luck with this one since there will be no one around to lay some colorful language on lol.
scippy is offline
Old 11-12-2021 | 06:17 AM
Hahaha, it will come out smooth, just keep the drive neutral with the helmet. Installation can be challenging, I've slid it in first try and was completely shocked. On other occasions I need to walk away for a few minutes after messing with it for half an hour. If you have the springs on the tail stock it will be much easier, I don't have them. I would make a you tube video, but guaranteed that would be the time it does not co-operate!
Old 11-12-2021 | 12:41 PM
scippy's Avatar
Just to understand, the springs on the tail stock (don't know if I have them since its my first time at this ) are a sort of guide to help in re-attachment?........also, when all of the 6 gimble bolts are out, dose the outdrive tend to just fall away and separate?..or does it usually take a bit of nudging it to separate?
scippy is offline
Old 11-12-2021 | 02:08 PM
Yes the spring is to guide the yoke into the tail stock. The friction on the studs is the only thing stopping it from coming apart. A little pulling while taking some weight with the hoist and it will slide out.
File Type: pdf
File Type: pdf
