SSM3 oil leak
#33
The Drive separated with no problem getting back in big problem.
#34
What is sure is the splined shaft doesn't align with the coupler @ the trans.....searched video's of #3's but all
there is is Bravo's and Alpha's
#35
If it came out and was fine before and you didn`t move anything how could it all of a sudden be misaligned? You `re not making any sense .
Put it back the way it came out .
It can be a real ***** to put back in, just because you can`t do it doesn`t mean it`s misaligned.
I use masking tape to tape the u joints straight , once the motor turns over the masking tape will break apart
#36
that's not the problem...... something moved maybe under tension don't know why, but here I am!
#37
Today I pulled the starboard drive replaced the leaky oil line and within seconds of the first try "boooom" the drive re-attached like butter.
So as far as the port (problem) drive, we'll need to separate the engine from the tailstock something is frozen in there
#38
That's the way it goes with me sometimes, one is easy, while to other is not.
If it was misaligned to point of not being able to get the spline in, you should be able to see it from the outside looking in when the drive is off. I have also slid the bellows off to align the shaft, it's not easy but you can see what is going on.
#39
#40
The tail stock of the transmission fits into the transom assembly pretty snug, so unless the receiving portion of the transom assembly is out round or the tail stock on the transmission is wrong, the only way to adjust alignment is raise or lower the front of the engine, which as you have seen makes very little difference in the tail stock position in the transom assembly.
Hopefully someone with rigging experience can offer their insight.
As far as worn out components in the transmission being a contributing factor, I have no idea.
Is the input on the transmission in the center of the tail sock?
