Drive shower for high x dimension
Hey guys just considering a drive shower for my Bravo XR. Most seem to get the water from above the prop. Mine run as almost surface drives so I would assume I would be getting no water when it is most needed. Has anyone ran the pickup off the transom or have any other ideas? Just seems like a waste on a lot of these newer boats with high x dimensions.
I’ve seen folks put pickups
In K planes and plumb as needed
Thanks guys I have my intake in the drive which is a little sketchy. My x is extremely high. I was thinking if I did one to put it on the transom but I would hate to drill holes
where is the prop shaft in reference to the bottom of the hull
my propshaft is 1” above the bottom.
Don’t most drive showers rely on the rotation to the prop to push water up the shower tube? The drive shower pickup is not like a thru hull pickup relying on the water itself to force it in while moving.
The following 3 users liked this post by IGetWet:
Just got down to measure. It’s about 2” below in a staggered installation. I know they had to raise the hatch to get them to fit. It is a 36 Pantera. Only one with a staggered set up
notched at the transom or no, let me know when it for sale .........Im running 2.5 inch below with no issues
