Having trouble removing 1 inch tips from 98 312 fastech >
Old 02-28-2006 | 08:30 AM
Default Having trouble removing 1 inch tips from 98 312 fastech
I removed the silent thunder box and now i'm trying to get the stock 1 inch exhaust tips off. Besides the 3 screws that hold it to the transom is there anything else? I cannot seem to break it loose from the silicone and chaulk. Sugesstions? I bought the corsa slant cut tips with internal flappers and anxious to get them on! thanks
Mark
chattviper is offline
Old 02-28-2006 | 08:34 AM
From: A tree somewhere in the woods in Clarcona Fl.
Default Re: Having trouble removing 1 inch tips from 98 312 fastech
When I changed the tips on my Baja Outlaw, I pulled the exhaust hoses off and then took a piece of 4" pipe and smacked them loose from the inside.
Slick02 is offline
Old 02-28-2006 | 09:58 AM
smack that 3M 5200 all you want. heat is the only way! heat up the dia. of the flange where it meets the tubing with a torch a little at a time. you'll hear the 5200 popin' a little. remember a little temp at a time 'cause there's a thin line between getting the tubing and the flange hot enough to transfer enough heat into the 5200 to release it...
and hot enough that so much heat get's transfered that the gelcoat "browns" a little around the flange.
I got mine hot enough to brown the gel a little (un-noticable, and mostly covered by the larger dia. of the Corsa "can") and it still wasn't totally released...brought a few flakes of gel from the edge with it.
heat, take your time, and one at a time!
Attached Thumbnails Having trouble removing 1 inch tips from 98 312 fastech-ass.jpg
Rippem is offline
Old 02-28-2006 | 10:13 AM
Mine didn't have 5200 around them, looked like the 4200 when I got them off.. With the 5200 you could destroy the gelcoat and still couldn't get them off...(made that mistake with my older Formula and a vhf antenna mount)
Slick02 is offline
t500hps
07-14-2015 12:33 PM
gcoutlaw
08-31-2007 08:35 AM
JEFF CHRZANOWSKI
4
08-23-2007 11:56 PM
Crazyhorse
07-19-2006 12:40 PM
