Smoke coming from starboard side of thunder box! >
Old 03-29-2007 | 08:01 PM
masi242's Avatar
You should be fine
Attached Thumbnails Smoke coming from starboard side of thunder box!-summer-04-large-.jpg
masi242 is offline
Old 03-29-2007 | 08:44 PM
offthefront's Avatar
Originally Posted by Hazlnut
I am getting stem and the starboard side riser is way hotter than the other. So much hotter that I can barly hold my hand on it. Sounds like I have a blockage issue.
Check the impeller .....and while you got the hose off the sea pump ....pull the hose on the intake side of the Thermostat housing and backwash the whole system ...Put an old nylon stocking over the hose off the seapump the one going TO the PS cooler (above the bellhousing) ....m
offthefront is offline
Old 03-30-2007 | 10:46 AM
Well there is a screen in the p/s cooler though correct! That should catch everything.
Hazlnut is offline
Old 03-31-2007 | 01:41 PM
There is no screen in the P/S cooler ....Nor the oil cooler ...The P/S cooler is just a hollow tube ...the oil cooler has small tubes the water flows thru and that is where it clogs .....m
littledcsrodshop
Wanted
2
06-11-2008 11:01 PM
cougarman
Active Thunder
5
01-05-2006 02:13 PM
Elite Marine
2
09-10-2002 09:06 AM
Elite Marine
8
09-09-2002 05:48 PM
FBRONCO
1
05-17-2002 08:48 PM
