New Taco Rub Rail >
New Taco Rub Rail
New Taco Rub Rail
Old 07-07-2007 | 10:32 PM
Prater's Avatar
Thanks for the link.
Prater is offline
Old 07-11-2007 | 06:40 PM
Anyone interested in going in on a 200' roll, should do 2 boats with a little left over.
Treads is offline
Old 07-11-2007 | 08:40 PM
masi242's Avatar
nice job, it cleans it real nice.
masi242 is offline
Old 07-11-2007 | 09:23 PM
mtgbiker's Avatar
Thanks,
I figured White rub rail would update the look of my older bird!
also,
I believe Formula changed from Black to White in 95 or 96?
mtgbiker is offline
Old 07-12-2007 | 01:39 PM
How was your rail attached to the ST platform? Mine's done with rivets instead of screws like the rest of the boat.
handfulz28 is offline
Old 07-12-2007 | 04:05 PM
Mine is the same also.
Treads is offline
Old 07-12-2007 | 05:03 PM
mtgbiker's Avatar
Ditto, Ditto
Drill em' out...seal em' with 5200 and drill new holes since Taco's rub rail comes pre-drilled (8" on center) anyway!
mtgbiker is offline
Old 01-03-2008 | 07:28 AM
freddan's Avatar
Originally Posted by mtgbiker
iboats.com
Frosty White-Perfect match
The Artic White is too white.
http://www.iboats.com/1_7_8_Frosty_W...view_id.271971
I hope this link works. If not, I can send you a PM. Let me know.
Oh no... cant find the Frosty white rubrail on their site? I was just about to place an order
Is it available somewhere? Please help!
freddan is offline
Old 01-04-2008 | 07:36 PM
propwash's Avatar
Hey guys, I just got done doing this rub rail replacement and I would recommend to get some samples of the different profiles and colors you think you may want for your boat. Take a piece of your rub rail off and then put the sample up to the boat and see if it's going to cover where the old one was. This is not the easies job to do and very time consuming but worth ever minute when it's done. I did use the Taco's rub rail that I believe measured 1& 15/16 in height. Take your time and I'am sure it will turn out real nice. Sorry I don't have any pictures but I wish I had. Changing the rub rail is a big improvement to these old birds. Propwash.
propwash is offline
Old 01-04-2008 | 08:09 PM
Did the old rub rail unscrew from the screws on the outside? I was once told you had to remove the interior upholstery!
MOERON is offline
