Prop Question >
Prop Question
Prop Question
Old 08-08-2007 | 09:46 PM
Default Prop Question
Hey Guys I Am New To Oso And The Formula Form My Question Is I Have A 1992 242 L/s With A 502 When Running With 5 People Onboard Takes A Long Time To Come Out Of The Hole And Get On Plane I Am Running A 23p S/s Should I Go To A 24p Or 26p To Help Or Will I Lose A Little Top End
lv92780 is offline
Old 08-08-2007 | 09:47 PM
t500hps's Avatar
21 and 42 footers
You have the right idea, but your going the wrong way with the pitch. Better hole shot-----less top end. But to acheive that you need to DROP the pitch, not go up.
t500hps is offline
Old 08-09-2007 | 05:04 AM
Iggy's Avatar
Yeah, go down in pitch....not up.
And watch your max rpm at WOT. Do not exceed recomended operating RPM.
Rule of thumb...
For evey inch of pitch decrease RPM goes up about 100 rpm.
Just the opposite when increasing pitch.
Iggy is offline
Old 08-09-2007 | 10:04 AM
Rambunctious's Avatar
tell us what your wide open rpm is after you get on plane and we can steer you to the right pitch.
23 is about appropriate
if you wnt from a small runabout to this boat, expect more time to get on plane as these types of boats are pitched to go fast and not pull tubes or skiier quickly out of the water....
I commented in your other post as well
Ramb
Rambunctious is offline
Old 08-09-2007 | 10:30 PM
Hey t500hps and Ramb thanks for the advice will let you know what top rpm is after this weekend thanks again..
lv92780 is offline
Old 08-11-2007 | 10:21 AM
Hey Ramb I looked for your info you posted of the removeal of the baffles can't seem to find it can you let me know were it is thanks.. Thanks for the info on the prop ..
lv92780 is offline
Old 08-12-2007 | 03:41 AM
masi242's Avatar
I`m running a 22pitch labbed four blade on my 242LS with the 454. It does a great job,but when you start to add more people use your tabs it will help.
masi242 is offline
Old 08-12-2007 | 11:31 AM
Thanks masi242 trying it out today..
lv92780 is offline
Old 08-13-2007 | 04:13 PM
Here it is
http://www.offshoreonly.com/forums/s...ad.php?t=32207
Ramb
bimmerboy318
Prop Talk
7
07-12-2008 09:46 AM
fountain 47 sc
Drives and Lower Units
1
03-09-2008 07:57 PM
Sea-Dated
Prop Talk
15
06-02-2006 04:49 PM
Excalibur502mag
0
08-12-2004 12:40 AM
FlyFast
1
08-06-2004 10:22 AM
