242ls Rubstrip replacement >
Old 04-25-2004 | 04:19 AM
bobbarker's Avatar
Default rubrail replacement
jrocket,
After you remove the old rubrail make sure you
tighten all the screws that holds your top deck to
your hull. You probably know this already that your
boatis made in 2 pieces, then screwed together. As
your boat gets older the screws tend to loosenan
causes flexing or movement in the 2 halfes. Tightening
these screws will reduce or stop that flexing, but you
probably knew that to.
bobbarker is offline
Old 04-25-2004 | 06:49 AM
Audiofn's Avatar
Charter Member #232
Or if you REALLY want to go nuts take out all the screws, remove the rubrail, clean out btwn the two hull halfs and use 5200 btwn then through bolt everything back together. You will be AMAZED at how much more solid the boat feels. TACO DEFINATLY makes the insert for that boat however I am not sure if they make it in white, I think only black. I do wish that when I did mine that I used the rub rail similiar to the Fast Tech boats. They are a solid color and last time I talked to them about price it was not to outrageous.
Jon
Put your best foot forward!
Audiofn is offline
88242LS
08-06-2021 04:46 PM
BlackJack58
02-25-2008 03:35 PM
oreokid220
09-06-2007 08:31 AM
JON242
10-20-2002 10:17 AM
jrocket
10-02-2002 03:43 PM
