Clear water inticators (Cable replacement) >
Old 05-03-2002 | 10:58 PM
Preferredstock
Default Clear water inticators (Cable replacement)
I am about to replace the drive cable. One of them is broke. Should I replace them all, or just the one that's broke. Anybody have any tricks of the trade of helpful hints??
Thanks in advance.
Bill Stock
Old 05-04-2002 | 05:29 PM
mfb357's Avatar
Bill, I would replace all of them they are like tires if one wears they all wear. As far as replacing them , use an old one and pull the new ones by taping them to the old one and gently pulling them through. You may have to cut some wire ties along the way if they jam. If you remove all the old ones except for one they should pull O.K. Good Luck, MFB
mfb357 is offline
Old 05-04-2002 | 05:50 PM
Audiofn's Avatar
Charter Member #232
I am going to put a emphasis on GENTLY pull them through. I have seen people yank them through and mess up electrical stuff. So take your time it is an easy job but does take time.
Jon
Put your best foot forward!
Audiofn is offline
Old 05-04-2002 | 11:18 PM
What's a clear water inticator?
Chart is offline
Old 05-06-2002 | 05:42 PM
Preferredstock
I was kind of planning on doing them all. Your right about one going and the rest are not far behind. It sure doesn't look like too much fun.
Chart
They are the cable on the drives and the tabs that tell you where the drives and tabs are.
Wish me luck
Bill
Wildman1
Powerquest
3
08-25-2007 09:19 AM
t500hps
8
02-17-2006 08:34 AM
Lmarth
11
10-30-2004 07:48 AM
Interceptor
2
07-19-2004 03:40 PM
