IMO......Formula may have a safety isssue with the hull/deck bonding.
#91
The way I seperated the hull halfs on my 302 was use a hack saw blade on a funky cutter my brother had. Had to be SUPER carefull to not cut into the deck or hull. I have no idea what the bond was made out of as I know that back then Formula did not use anything, so I assume that it was something that one of the previous owners had done.
Put your best foot forward!
#92
Sorry......I miss read your post. The only loose rub rail screws I have had are because the head of the screw (under the rub rail) came off with the broken screw.
Are you indicating that you need to periodically remove your rubrail and tighten the screws holding the deck?
no, I was not saying that I ever needed to remove the rubrail to tighten loose through bolts.
#93
This photo was taken from the engine room forward of the starboard engine. When we pulled the rail and repaired the joint there was NO PLEX in this area NONE!. In general on my boat there was not enough plex in the seam.In most places there was just one line installed and then over squeezed. Upon repair we installed enough to squeeze out the top and the bottom of the seam. Plex wants at least 1/8" of material left in the seam, careful not to oversqueeze! As you can see there is no plex squeezed from the joint forward of the gob. Operator error...yes I agree..
When you say that Plexus wants at least 1/8" in the joint, do you mean 1/8" thick? Can you have more?
#94
This is the really scary part of this. Formula shows them putting the bead of Plexus on, and then lowering the deck over it. If I understand the video and the pictures correctly, it should be impossible for the plexus to get where it is on your boat. I would think that if it got moved, it would be pushed down on the hull when the deck is lowered. IOW, it looks like on your boat that someone screwed up BADLY!
#95
They say a minimum of .05". Thats 1/2 the amount that FF quoted. I've also seen other companies quote between .01 and .03 minimum.
IOW it doesn't seem as if there has to be much in there. Less seems to be better When Formula bolts those joints together I don't think they squeeze it thinner than the above.
#96
Going to my storage today to check on mine. For my sake I'm hoping Formula was more deligent using Plexus on the early boats, as the process being new to them and they wanted to make sure it was done right. I feel for anybody having to deal with this.
Believe me I know that sinking feeling when you realize that your Formula isnt indestructable. Found bad bulkheads in my 311 from a leaking windshield. Bought the 353, found water in the transom from improperly installed exhaust tips and extension boxes(not factory installed).
Makes me wonder about the grid system now. Did Formula start getting sloppy on the production process??
Hope not..
LE
Hope not..
LE
#97
Bottom line is.......boats are failing and could be a safety issue if ignored.
- The fiberglass is not ripped apart.
- Plexus works properly if installed per recommendations.
- Decks are separating from the hull.
This is not the end of the world. The repair didn't take that long, and it wasn't THAT expensive.
#98
#100
That was my point a while back.
No one is sure what or if this is an issue. I see the picture (ONE), and hear the claims, and they very well may be correct. but, IMHO, I highly doubt that this is any kind of the issue that some may think. PhantomChaos's boat is a 2001. Thats 10 YEARS ago. If this was an issue, throughout the entire line or on all boats, I would sure think that we would have heard something about it before now. 10 years is thousands of boats. So far one picture of a small section that is said to not have Plexus in it, and thats it.
I'm not trying to cast doubt on anyones claims here, but that is all any of us have seen, is one picture. I'd love to see the repair pics, or the no plexus pics, or anything that shows that this is an issue. This is a VERY serious allegation again a very respected builder, and as such, I'd like to see more than what has been produced so far.
