IMO......Formula may have a safety isssue with the hull/deck bonding. >
Old 05-23-2011 | 11:58 AM
  #221
Registered User
I checked out my 353 and found it to be solid, nothing loose at all. Keep us updated, thanks.
Fastech 353 is offline
Old 05-23-2011 | 03:08 PM
  #222
My friends 06 382 is tight. Lake Michigan
Back4More is offline
Old 05-23-2011 | 03:17 PM
  #223
I checked mine as much as I could without dis-assembling it...looks good to me.
1MOSES1 is offline
Old 05-25-2011 | 04:55 PM
  #224
Default 382 plexus problems
On my 1998 382 the plexus bonding deck/hull was loose all the way around. I cut out everything inside the boat (even the floor and the toiletroom) to glass the parts together-doing a complete rebuild. Then i discovered the stringer was loose in many places also......because the deck/hull bonding was loose, it allowed water to enter the cabin. The water found its way all the way down to the stringer, and because the stringer was loose in many places, it even entered the foam inside. This water will not ever go away !
Now i have cut away most of the part of the middle stringer and glassed the hole thing to the hull.
I also drilled some holes in the stringer and removed the foam inside.
The boat is back on the water. It floats a lot higher in the water, and its a dream to drive. It feels extremely solid.
I have diesels in the boat and it comes on plane a lot easier now. The topspeed is nearly 60 knots with merc 350 hp diesels and 32 labbed maximus at 3800 rpm.
I have talked with the guys at Formula, but they told they never have experienced any problems like this......
Gorm, Norway.
Gorm is offline
Old 05-26-2011 | 12:54 AM
  #225
PhantomChaos's Avatar
Gorm, Norway.
Wow.......! Why does it float higher in the water?
PhantomChaos is offline
Old 05-27-2011 | 06:35 AM
  #226
Audiofn's Avatar
Charter Member #232
Less water in the boat....
Put your best foot forward!
Audiofn is offline
Old 05-27-2011 | 11:19 AM
  #227
J.B. Marshall's Avatar
JB Marshall
All the parts he cut away and tossed out
J.B. Marshall is offline
Old 05-29-2011 | 07:03 AM
  #228
I'm curious to know why this problem was not reported as a warranty issue in 2003 when the 20+/- screws were first found to be broken?
tpenfield is offline
Old 05-31-2011 | 11:03 AM
  #229
See post 65 and 78
Old 05-31-2011 | 06:54 PM
  #230
All I know is if the weather does not warm up I am off to Marathon, FL
fossil fuel is offline
