Ideas for cooling down 292 engine compartment >
Old 08-04-2016 | 10:03 PM
  #61
[ATTACH=CONFIG]558029[/ATTACH]
papps is offline
Old 08-04-2016 | 10:05 PM
  #62
I placed the probe between both engines just to get an idea of bilge temps, next test would be to place it next to flame arrest or to see what in,et temps are.
papps is offline
Old 08-04-2016 | 10:06 PM
  #63
[ATTACH=CONFIG]558030[/ATTACH]
papps is offline
Old 08-04-2016 | 10:09 PM
  #64
The above pic was running at about 4000rpm and I had to look over my shoulder and take this pic while not killing myself. Bilge temps actually dropped as I increased speed so probably means I have good airflow to the engines.
Still made me think that a ram air would pick up performance.
papps is offline
Old 08-04-2016 | 10:11 PM
  #65
[ATTACH=CONFIG]558031[/ATTACH]
papps is offline
Old 08-04-2016 | 10:14 PM
  #66
The above pic was idling after a high speed run, temps gradually increased to 20+ degrees above ambient. Proves the bilge blower is most useful when idling. Also, I always crack the cover whenever I stop in the summer.
PM me if you need more info on the Fluke meter.
Pat
papps is offline
Old 08-06-2016 | 04:06 PM
  #67
[ATTACH=CONFIG]558060[/ATTACH]
Here is a shot of the markings on top
Hope it helps
Attached Thumbnails Ideas for cooling down 292 engine compartment-20160806_125336.jpg
COOPS is offline
Old 08-06-2016 | 05:03 PM
  #68
Revspan's Avatar
Any chance to get a better shot of the part number? I tried to blow it up, but could not read it. Thanks a lot.
Revspan is offline
Old 08-06-2016 | 05:30 PM
  #69
Originally Posted by revspan
any chance to get a better shot of the part number? I tried to blow it up, but could not read it. Thanks a lot.
a7390-2
COOPS is offline
Old 08-06-2016 | 11:11 PM
  #70
TomZ's Avatar
Been reading through the thread, and thought I'd comment.
Just as you need to get good air in there, you need to get the bad air out. I've noticed with my 242 that there are intakes for getting "some" air into the bilge, but no extraction. On my buddy's Cigarette, the bilge is set up to ventilate quite well. The rear quarter on each side and the entire stern are open to the atmosphere. I believe that at speed there is a suction created at the stern that pulls air through the bilge. Our Formulas do not have this (my 242 doesn't). My other boats have had this set up (Four Winns and Chris Craft), but not this one. If I didn't think it would screw up the lines of the boat, I'd add vents just under the grab rails at the stern to help this along. I wonder how hard this will make getting my 454 into 5800-6K range rpm-wise?
Chasing out that tiny arrestor will definitely help in terms of air flow, but you still need fresh air.
TomZ is offline
