Question on Trim/Pumps >
Old 04-16-2019 | 07:10 PM
That screw is the dip stick and the screen is on the bottom of the pick up in the reservoir. You have the older style and I’m not sure how the tank is attached on those. On the plastic tanks there is a screw on the bottom and a quarter twist to remove the reservoir
ph1971 is offline
Old 04-16-2019 | 07:39 PM
[QUOTE=The Sheikh;4682407]Okay, Guys. I removed my engine cover to clean some things up last night, and I located the trim pumps. They do not look like the one pictured above. I took the best photos I could. Can you guys give me some advice on these?
If some one put the trim solonoid wirez on the tilt solonoid then it would behave like said
oconnor marine is offline
Old 04-22-2019 | 08:35 AM
[QUOTE=oconnor marine;4682485][QUOTE=The Sheikh;4682407]Okay, Guys. I removed my engine cover to clean some things up last night, and I located the trim pumps. They do not look like the one pictured above. I took the best photos I could. Can you guys give me some advice on these?
So if the Trim hose in the tilt hole on the trim cylinders manifold on the outside of the boat under the transom plate. Swap them and see what happens. is what i meant to say. Is what can do what you are describing
Old 05-30-2019 | 03:11 PM
So, as a follow up, the electric motor on that pump was bad. Replaced it and everything works great.
Thanks for all the help!
J
The Sheikh is offline
